408 PUMP GAS STROKER DYNO RESULTS :) #1516797
10/13/13 04:04 PM
10/13/13 04:04 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Some of you may remember my 360/408 pump gas build (Mike Thompson Racing Engines)
Well.....awhile back a local Mopar Nut made me a deal on the 408 I couldn't refuse....long block minus tunnel ram and carbs.
Great guy with a beautiful Scamp....street car, 727, 3500 stall vert, 3.91 gears, 26" tires, 1 5/8" long tube headers, 2.5" exhaust through turbo mufflers.
Made 391 HP the other day on a chassis dyno on 93 pump swill
I was quite impressed with the numbers for a J-headed 408....only change was a airgap intake and 800 vac holley carb.
So i'm guessing 460 - 480 at the flywheel...?????
Anyway.....he's a happy camper
Rickster
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: rickstershemi] #1516798
10/13/13 05:02 PM
10/13/13 05:02 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
so what you do with the Valiant?
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: Randy..] #1516799
10/13/13 05:33 PM
10/13/13 05:33 PM
Sitting in the garage......
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: rickstershemi] #1516800
10/14/13 04:39 PM
10/14/13 04:39 PM
So watcha think.....might step it up next time...have a possibility of trading the Valiant for my old challenger bracket car... I sold back in the early 90's and has resurfaced
Rickster
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: rickstershemi] #1516801
10/14/13 04:53 PM
10/14/13 04:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Those are good #`s and my dart at 3200 bs. w/similar #`s went high 11`s at L.A.C.R. years ago...........daily driver w/stock smog heads w/a Pettis clean up and valve job. Should b fun..........
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: Thumperdart] #1516802
10/15/13 12:37 AM
10/15/13 12:37 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
390 at the wheels in a 3k pound car set up correctly is 10.90 territory.
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: Thumperdart] #1516803
10/15/13 09:37 AM
10/15/13 09:37 AM
Gonna find out what it runs in street trim shortly....he's planning on hitting the local 1/8 mile tnt here shortly.....he's a newbie so could be interesting....we'll see....gotta start somewhere
Rickster
Re: 408 PUMP GAS STROKER DYNO RESULTS :) [Re: rickstershemi] #1516804
10/15/13 09:38 AM
10/15/13 09:38 AM
tboomer Offline
tboomer  Offline
Good luck Rick! Let us know the results!
