68 Dart lower control arm #1516746
10/13/13 02:12 PM
10/13/13 02:12 PM
Morris County NJ
Rustydog Offline OP
Rustydog  Offline OP
Morris County NJ
I have a 68 Dart.
I converted to front disks. I used parts from a 74 Dart. Everything works great but the tire / wheel combo that I want to use is too far outward. In otherwords, the tire is to close to the fender and the front tire tracks are farther apart than the rear tires. I am using 15 x 7 wheels with a 4 inch backspace. The 15 x 6 inch factory steel wheels also have a 4 inch backspace and look better on the car but are still a bit too close. I guess that the disk brakes put the wheel outwards more than the factory 10 inch drum brakes. So heres my dumb question:
Is there any other mopar control arm that is shorter in length than the one on my 68 Dart?
I'd like to move the whole assembly inwards 1-2 inches. Any ideas would be helpfull. Thanks.
Re: 68 Dart lower control arm [Re: Rustydog] #1516747
10/13/13 02:29 PM
10/13/13 02:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You have to just change the back spacing on the wheels you are running.
Not really a way to move the hub face/spindle/control arms inwards 2"
Re: 68 Dart lower control arm [Re: Rustydog] #1516748
10/13/13 02:31 PM
10/13/13 02:31 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I have a 68 Dart.
Did these same exact tires and rims fit your old drum brake setup. I don't think so, since you changed from small pattern to large pattern.
The 73-76 large bolt pattern disk setup only move the wheels out about 1/4" to 3/8".
Do not change the lower control arm length. You will never get the car to align right. That is not the right way to fix your problem.
Get the correct backspacing rims and right size tires for your car.
You have too wide, too tall, and/or not enough backspacing rims. Or or a combination of those things.
Re: 68 Dart lower control arm [Re: autoxcuda] #1516749
10/13/13 06:55 PM
10/13/13 06:55 PM
Morris County NJ
Rustydog Offline OP
Rustydog  Offline OP
Morris County NJ
Yeah, I now have the large bolt pattern. The 8-3/4 original rear was removed and I installed a shortened Dana 60 which also has the large bolt pattern. BTW car has a 440 with a Borg Warner overdrive 5 speed.
The original steel wheels were 14x5 with a 3 inch backspace.
Now the 15 X 7 wheels with a 4 inch backspace is just too wide. These wheels don't come with a 5 inch backspace. That would solve everything. In fact, I can't find any 15 X 7 wheels with a 5 inch backspace. These wheels are also not available in 15 X 6. That would also be somewhat better.
Re: 68 Dart lower control arm [Re: Rustydog] #1516750
10/13/13 07:54 PM
10/13/13 07:54 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Depending on the type of wheel you are running, you may be able to move the center that far out... (done it with aluminum before at least) with a steel wheel, the drop center where the center welds into might not reach to were want, just depends on the style as said...
(or a larger diameter wheel perhaps, or a 15 x 6, depending on the look you want?)
Re: 68 Dart lower control arm [Re: Rustydog] #1516751
10/13/13 08:02 PM
10/13/13 08:02 PM
So Cal
So Cal
What tire size are you running up front? It is too tall or too wide.
I can fit 225/60/15 tires with 15x7 ralley/cop/mopar steel rims that have 4.25 backspacing with a 73-76 disk swap on a 68 Dart.
Is your current setup make the tire rub on the front bottom fender lip edge of the fender?
Re: 68 Dart lower control arm [Re: autoxcuda] #1516752
10/13/13 08:06 PM
10/13/13 08:06 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Good point Steve, forgot to even bring up the tire size..
(PS. Long Beach was packed this morning!)
