Re: overheating
[Re: komninon]
#1516177
10/12/13 03:36 PM
10/12/13 03:36 PM
RapidRobert
You need a smaller WP pulley to speed up the fan for more airflow & side bennie of more coolant flow
Re: overheating
[Re: moparcanuk]
#1516180
10/12/13 10:36 PM
10/12/13 10:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I did it all and eventually installed a 160 stat which solved all my heating problems.
You realize a thermostat does NOTHING for maximum temperature. It only sets the minimum. If a new thermostat "fixed" the problem then the problem was the old thermostat, not the temperature rating of it.
I think the OP found out that his cooling system had barely adequate airflow then he installed a condenser which took him into the inadequate airflow category. Your fan is not pulling enough. You need more airflow, get rid of the aftermarket junk. A factory shroud, fan and AC pulley setup will fix your problems. Never understood why people scrap a system with millions of miles of proven performance (factory radiator, shroud, fan setup) and slap on a bunch of aftermarket bling then wonder what happened.
Re: overheating
[Re: Supercuda]
#1516182
10/13/13 01:25 PM
10/13/13 01:25 PM
Posts: 1,522 Orleans, Ontario
moparcanuk
Orleans, Ontario
Exactly. if you're running a 195 stat, your motor can't get any cooler than 195. The only way it has to go is up.
Re: overheating
[Re: Supercuda]
#1516183
10/13/13 02:53 PM
10/13/13 02:53 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I put MY money where my beliefe is. im right!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: overheating
[Re: komninon]
#1516186
10/13/13 09:07 PM
10/13/13 09:07 PM
RapidRobert
Yeah I'd get a 7 blade rigid fan/properly spaced & see if the stoplight to stoplight cruising temp comes down from 225. Even with the cooler ambient temps you'll know if it is working. Holler how things turn out
