overheating #1516174
10/12/13 02:59 PM
10/12/13 02:59 PM
chicago il usa
K
komninon Offline OP
komninon  Offline OP
K
chicago il usa
Reply with quoteQuote Modify messageModify
never had overheating problems before, 26" aluminum radiator, shroud, 6 blade nylon mechanical fan. always 195 in bad traffic and 180 on the highway.
just installed new ac system, gets up to 225 in traffic which I do not like, and 190 on the highway which I think is ok. should I go with 7 blade 216 fan? is it going to have more air flow a idle?
do I need a bigger radiator? or installing a pusher electric fan in front the condenser will help?
Re: overheating [Re: komninon] #1516175
10/12/13 03:10 PM
10/12/13 03:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have any space between the condenser and the radiator?
Re: overheating [Re: stumpy] #1516176
10/12/13 03:12 PM
10/12/13 03:12 PM
chicago il usa
K
komninon Offline OP
komninon  Offline OP
K
chicago il usa
about 1/2"
Re: overheating [Re: komninon] #1516177
10/12/13 03:36 PM
10/12/13 03:36 PM
You need a smaller WP pulley to speed up the fan for more airflow & side bennie of more coolant flow
Re: overheating [Re: RapidRobert] #1516178
10/12/13 10:12 PM
10/12/13 10:12 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I did it all and eventually installed a 160 stat which solved all my heating problems.
Re: overheating [Re: komninon] #1516179
10/12/13 10:32 PM
10/12/13 10:32 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes, get rid of that plastic fan.
A "216" fan would be my choice. I them on both of my cars and they cool well in traffic at idle. I also have R134 AC and the 216 fan and shroud pulls enough air at idle to make my AC work at idle when it's hot and the clutch is locked up. You can actually hear the fan when the clutch is locked up.
Great setup IMO, way better than a plastic flex fan.
Re: overheating [Re: moparcanuk] #1516180
10/12/13 10:36 PM
10/12/13 10:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You realize a thermostat does NOTHING for maximum temperature. It only sets the minimum. If a new thermostat "fixed" the problem then the problem was the old thermostat, not the temperature rating of it.
I think the OP found out that his cooling system had barely adequate airflow then he installed a condenser which took him into the inadequate airflow category. Your fan is not pulling enough. You need more airflow, get rid of the aftermarket junk. A factory shroud, fan and AC pulley setup will fix your problems. Never understood why people scrap a system with millions of miles of proven performance (factory radiator, shroud, fan setup) and slap on a bunch of aftermarket bling then wonder what happened.
Don't be the exception.
Re: overheating [Re: Challenger 1] #1516181
10/13/13 11:06 AM
10/13/13 11:06 AM
good point on the fan, get rid of the flex fan & add a metal one with as many blades as possible & that'd be easier than finding the correct size/depth WP pulley (tho I have a bunch, PM as needed ) & if that dont do it then yes I would change pulleys. Holler how it turns out
Re: overheating [Re: Supercuda] #1516182
10/13/13 01:25 PM
10/13/13 01:25 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Exactly. if you're running a 195 stat, your motor can't get any cooler than 195. The only way it has to go is up.
Re: overheating [Re: Supercuda] #1516183
10/13/13 02:53 PM
10/13/13 02:53 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I put MY money where my beliefe is.
im right!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: overheating [Re: Copper Dart] #1516184
10/13/13 05:20 PM
10/13/13 05:20 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
im right!
You also put your fan to far into the shroud !
Re: overheating [Re: Challenger 1] #1516185
10/13/13 07:34 PM
10/13/13 07:34 PM
chicago il usa
K
komninon Offline OP
komninon  Offline OP
K
chicago il usa
thanks guys ,
i will try to find a 7 blade fan and see if that is going to work.
only problem is i live in Chicago and do not think we will have any hot humid days coming soon.
Re: overheating [Re: komninon] #1516186
10/13/13 09:07 PM
10/13/13 09:07 PM
Yeah I'd get a 7 blade rigid fan/properly spaced & see if the stoplight to stoplight cruising temp comes down from 225. Even with the cooler ambient temps you'll know if it is working. Holler how things turn out
Re: overheating [Re: 62maxwgn] #1516187
10/13/13 09:09 PM
10/13/13 09:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
im right!
Look again.
No fan
Re: overheating [Re: Supercuda] #1516188
10/13/13 09:28 PM
10/13/13 09:28 PM
Look again.
No fan
Komninion update us on what's going on
Re: overheating [Re: RapidRobert] #1516189
10/18/13 11:18 PM
10/18/13 11:18 PM
Copper Dart Offline
Copper Dart  Offline
Think again.....
naw, i dont think so.
too deep not!
Mom.
Ricky Valdes
