Mounting lexan.... #1515324
10/11/13 06:54 AM
10/11/13 06:54 AM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
Screws or pop rivets?
Thanks!
Re: Mounting lexan.... [Re: slantzilla] #1515325
10/11/13 07:01 AM
10/11/13 07:01 AM
gregsdart Offline
gregsdart  Offline
I used counter sunk allen bolts and beveled the holes in the lexan and used nyloc nuts to be able to pull the front and rear windows up against a foam seal with very little tension or distortion of the lexan. this kept mine from cracking. Same for the side windows, for convenience.
Re: Mounting lexan.... [Re: gregsdart] #1515326
10/11/13 10:19 AM
10/11/13 10:19 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
whitch ever you use make sure your holes are a little larger than your fastener to allow for expansion and contraction with out cracking.
Re: Mounting lexan.... [Re: slantzilla] #1515327
10/11/13 12:02 PM
10/11/13 12:02 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks!
Dennis years ago Dave & I did the rear with rivets. This last time we did the front we used countersunk bolts & nylocs. It's easier for removal & controlling the tightness of the fasteners! Looks nice too.
I have seen it with button heads also, whatever you prefer.
We used plasticcoat black paint for plastic around the edges, looks more professional.
If you want do a search on mounting lexan, Mr P had a lot of good tips.
Don
Re: Mounting lexan.... [Re: cudadon] #1515328
10/11/13 12:53 PM
10/11/13 12:53 PM
Park Forest, IL
Park Forest, IL
Thanks guys!
I like the countersunk bolt idea, but I'm afraid there are some area I can't get to the backside to put nuts on.
I have some nice stainless screws with large round heads that just might do the trick. It will look a lot nicer than the hex head sheet metal screws that were in there.
Re: Mounting lexan.... [Re: slantzilla] #1515329
10/11/13 01:06 PM
10/11/13 01:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Pop rivets would crack the lexan. Be sure to use nylon locking nut's, because you can't tighten them totally because it'll crack the lexan. Must leave them slightly loose so it can move with the car to keep from cracking. Lock nuts so they don't wind up on the track.
Re: Mounting lexan.... [Re: Challenger 1] #1515330
10/11/13 01:23 PM
10/11/13 01:23 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Duck tape and elmers glue!
I have always used the counter sunk screws. And a very big yes to leaving them a little loose as to not crack the lexan.
Back in the swing of things at Painless again! Great to be back!
