90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel #1514210
10/08/13 10:04 PM
10/08/13 10:04 PM
Washington Twp., Southern NJ
Fastfrankie Offline OP
Guys...
Im torn between a real nice 90 Ramcharger 360/auto with 80K original miles and a sweet 86 M1009 6.2 diesel CUCV Blazer with 87K original miles, depot rebuilt 6.2 and new TH400 trans. Both vehicles are super clean and are turn-key.
The Ramcharger is $1,500 cheaper than the military Blazer.
What would be the better vehicle as far as a little bit of off roading, mostly around town/highway driving, climbing steep hills, and towing capacity.
I'm surprised the 6.2 diesel isnt very powerful making well under 200 horsepower...and the Blazer has stock 3.08 gears...wondering if its a dog off the line?
Feel free to chime in and let me know your thoughts...
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Fastfrankie] #1514211
10/08/13 11:19 PM
10/08/13 11:19 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'm pretty sure the 6.2 in that year is non turbo, really gutless, I drove an 89 Ford F250 4x4 ext cab long box 7.3 non turbo and it was an absolute dog.
The 360 would kick its hiney all over the place, that said I'm sure you could get a turbo kit for it. Now you have to ask yourself why did it need a reman engine at 87K? I don't think the 6.2's were that great of an engine
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: WO23Coronet] #1514212
10/08/13 11:21 PM
10/08/13 11:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My buddy had a 6.2 diesel in a 95 Chivvy dually, two engines broke crankshafts!
JB Rhinehart, Realist
A-Body's RULE!
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Rhinodart] #1514213
10/09/13 07:24 AM
10/09/13 07:24 AM
Its non-turbo...
As far as cranks breaking, I've heard that also...I've also seen these 6.2's with new harmonic balancers installed...that would explain cranks breaking!
I'll have to go check out the Ramcharger
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Fastfrankie] #1514214
10/09/13 08:38 PM
10/09/13 08:38 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
As the owner of a 6.2 powered Suburban, you definitely won't want one for power or towing. It will beat the 360 hands down for fuel mileage.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Cooter] #1514215
10/09/13 09:29 PM
10/09/13 09:29 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
IIRC the Military blazers also came with a 3.08 gear ratio. Not the best for offroading.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: hp383] #1514216
10/09/13 09:47 PM
10/09/13 09:47 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Yup.
And 10 bolts, too.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Cooter] #1514217
10/09/13 09:59 PM
10/09/13 09:59 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
And 10 bolts, too.
10 bolts are superior to any 8-3/4
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: hp383] #1514218
10/10/13 12:26 AM
10/10/13 12:26 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
And 10 bolts, too.
Not unless the 10 bolt is also stronger than a 9"------SAE tested the 8.75 to 500 hp and the 9 " only took 450 hp------yes the aftermarket chased the 9 (like the sbc) and you can buy tons of stuff for them but the bone stock 8.75 is stronger due to pinion placement---the 9 inch pinion placed at bottom of case is at the weakest spot---dana 60 near the middle is at the strongest position.....
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: hp383] #1514219
10/10/13 01:57 AM
10/10/13 01:57 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
And 10 bolts, too.
Huh, never had an issue in the one in my Jeep at the left.
Running 35x14.00 Boggers, Q78x15 Swampers, or 38.5x11.00x15 Boggers.
Jeep weighed 4K, as shown. Guys with the 10 bolts swapped under their much lighter CJs were lunching axles with great regularity.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Cooter] #1514220
10/10/13 09:44 AM
10/10/13 09:44 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Not all 10 bolts are the same and I doubt any are superior to a 8.75.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Soopernaut] #1514221
10/10/13 11:00 AM
10/10/13 11:00 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Chivvy went to 12 bolts for a reason and so the owners could finally use all their fingers to count the bolts...
A-Body's RULE!
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Rhinodart] #1514222
10/10/13 12:57 PM
10/10/13 12:57 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Rhinodart] #1514223
10/10/13 12:58 PM
10/10/13 12:58 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Some of the 6.2 diesels were quite frugal with fuel consumption. I've heard some guys claim 20+ mpg in the right circumstances. A 4x4 won't do as well as a 2 wheel drive though.
Parts for the 6.2's used to be relatively economical, by diesel standards. Unfortunately, the 6.2's will be more likely to break than some of the better engineered diesels.
The 6.2 seemed to be designed for light duty applications. I've heard that using them for towing and other heavy duty jobs will increase the odds of them giving trouble. I don't know how true this is though.
The 6.5 Diesel is an evolution of the 6.2 diesel. Some of the 6.5's had a turbo on them from the factory. I used to know a guy who was into the 6.2 / 6.5 engines. He swapped some heavier duty parts from the 6.5 onto the 6.2 to help the smaller engine live longer. I don't recall all of the details now.
The 1990 RC will be a TBI engine. Those have a reputation for being reasonably reliable, but not real powerful. If you can find a 92 or 93 magnum powered RC it will have more power.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: QuickDodge] #1514224
10/10/13 07:21 PM
10/10/13 07:21 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would love to drop a cummins 5.9 into a cucv set up--the ones i have seen around here have 1.25 ton rated axles--i have diesel emissions here so i think the swap would be doable---it would be fun to do the same to the 90 ramcharger but will not be allowed here by emissions rules...
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: savoy64] #1514225
10/10/13 07:29 PM
10/10/13 07:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
back on the axle shaft conversation----i had 9.25 cut down to A body width with 8.75 c-clip elimination for my 50 hudson----the guy that did the work is one of the top in the rocky mtn area---he told me the stock 8.75 axle is the strongest of the group and can be cut down and resplined---he also said only the ford 31 spline can be safely reused and the 28 spline ford should be thrown away---i ask him about the chevy axles--he said if you got a chevy throw that axle shaft away and go aftermarket....
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: savoy64] #1514226
10/10/13 08:05 PM
10/10/13 08:05 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
The truck CUCV had a D60/14 bolt combo.
The Blazer had 3.08 10 bolts.
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: savoy64] #1514227
10/16/13 11:00 PM
10/16/13 11:00 PM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Why would that not be allowed? The CTD was available in the dodge truck body since 1989, so as long as you meet the specs for a 90 CTD, I would think you would be fine. There no emissions on a 89-93 Cummins truck anyway....
Re: 90 Ramcharger 360 VS. 86 M1009 CUCV Blazer 6.2 Diesel [Re: Fastfrankie] #1514228
10/17/13 10:41 AM
10/17/13 10:41 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Given the choice b/t those 2, go w/ the ramcharger!
Used to have a 6.2 diesel in a 1/2 ton 2wd chevy truck. Decent fuel mileage, but that's the only good thing about it. NO power.
CHIP
'06 GMC 2500HD LBZ Duramax
