Page 5 of 7 1 2 3 4 5 6 7
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512344
06/11/14 12:57 AM
06/11/14 12:57 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Few more progress pics for those that care
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512345
06/11/14 01:01 AM
06/11/14 01:01 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
side view
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512346
06/11/14 01:03 AM
06/11/14 01:03 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
roll bar
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512347
06/11/14 01:05 AM
06/11/14 01:05 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Some of the sub-structure
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512348
06/11/14 01:07 AM
06/11/14 01:07 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Upper shock mount
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512349
06/27/14 10:37 PM
06/27/14 10:37 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Side bars
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512350
06/27/14 10:38 PM
06/27/14 10:38 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512351
06/27/14 10:43 PM
06/27/14 10:43 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512352
06/27/14 10:43 PM
06/27/14 10:43 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512353
06/28/14 12:24 PM
06/28/14 12:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
was going to drop you a note asking about this one.... get the powertrain figured out?
Re: 1965 Valiant wagon build ..Is underway [Re: J_BODY] #1512354
06/28/14 12:35 PM
06/28/14 12:35 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Small block but ,
transmission , still can't decide ?
and its to that point ..need to build trans mounts soon
Tempted to run a 3rd pedal
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512355
06/28/14 12:59 PM
06/28/14 12:59 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Looking very nice! I'm always amazed/impressed when someone can take on this sort of fabrication on their own. I need to take some welding classes...
2 kids and a dog
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512356
06/28/14 01:28 PM
06/28/14 01:28 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Its been record breaking cold
30 below and more
Been messing around cleaning parts and stuff but by time shop is warm, time to go to bed
Yeah, I bet you had to break the ice in the solvent tank just to clean parts. I'd imagine a lot of us didn't get as much as expected done last winter. Looking good!
Yeah, it's got a smallblock.
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512357
06/28/14 01:50 PM
06/28/14 01:50 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The plan / idea
Is to make inside nice , look close to stock as possible
Under hood, repaint/ detail
touch up body where really needed,leave rest
Drive to track, race drive home
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512358
06/28/14 02:02 PM
06/28/14 02:02 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Sounds like a good plan and fun ride.
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512359
06/28/14 05:29 PM
06/28/14 05:29 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'd look at a Metric 200 OD trans....
Nautilus Racing-
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512360
06/28/14 06:09 PM
06/28/14 06:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The plan / idea
A 518 bolts right up and gives you a 727 with OD..
change out the pump to a standard 727 pump and you
can run a high stall conv but you do lose lock up
and its cheap to do... you might need to work the
trans tunnel.. big deal where your at now
Re: 1965 Valiant wagon build ..Is underway [Re: MR_P_BODY] #1512361
06/28/14 06:23 PM
06/28/14 06:23 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I've been considering the 518
any drawbacks ?
http://www.transmissioncenter.net/SwapInformation.htm
Re: 1965 Valiant wagon build ..Is underway [Re: bigdad] #1512362
06/28/14 06:39 PM
06/28/14 06:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
any drawbacks ?
None that I see... unless you want a stock conv
with lock up... that will kill your launch .. I'm
happy with mine for a street/strip rod
Re: 1965 Valiant wagon build ..Is underway [Re: MR_P_BODY] #1512363
06/28/14 07:09 PM
06/28/14 07:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'd give up launch to have the benefit of torque converter lock up......
