Re: 1965 Valiant wagon build ..Is underway
[Re: J_BODY]
#1512354
06/28/14 12:35 PM
06/28/14 12:35 PM
Posts: 34,958 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Small block but , transmission , still can't decide ? and its to that point ..need to build trans mounts soon Tempted to run a 3rd pedal
[Re: bigdad]
#1512355
06/28/14 12:59 PM
06/28/14 12:59 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Looking very nice! I'm always amazed/impressed when someone can take on this sort of fabrication on their own. I need to take some welding classes...
2 kids and a dog
[Re: bigdad]
#1512357
06/28/14 01:50 PM
06/28/14 01:50 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The plan / idea
Is to make inside nice , look close to stock as possible
Under hood, repaint/ detail
touch up body where really needed,leave rest
Drive to track, race drive home
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#1512359
06/28/14 05:29 PM
06/28/14 05:29 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I'd look at a Metric 200 OD trans....
[Re: bigdad]
#1512360
06/28/14 06:09 PM
06/28/14 06:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The plan / idea
A 518 bolts right up and gives you a 727 with OD.. change out the pump to a standard 727 pump and you can run a high stall conv but you do lose lock up and its cheap to do... you might need to work the trans tunnel.. big deal where your at now
