AVS vacuum tube #1512142
10/04/13 12:42 PM
10/04/13 12:42 PM
NE
O
Oldstrtracr Offline OP
O
NE
Would like to know if vacuum tube on backside of AVS 4741, can be plugged. No hose from air cleaner to connect to it. 1970 Challenger 440. If plugged would that affect how it runs. Thanks
Re: AVS vacuum tube [Re: Oldstrtracr] #1512143
10/04/13 12:49 PM
10/04/13 12:49 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Plug it. No problem.
Re: AVS vacuum tube [Re: Oldstrtracr] #1512144
10/04/13 01:26 PM
10/04/13 01:26 PM
NE
O
O
NE
Thanks, trying to eliminate reasons why fresh rebuild runs so sluggish, will have to recheck MP distributor next. Thanks again
Re: AVS vacuum tube [Re: Oldstrtracr] #1512145
10/04/13 10:32 PM
10/04/13 10:32 PM
More details so we can try & help solve it. How it acts when did it start part or full throttle what changes were made etc
Re: AVS vacuum tube [Re: RapidRobert] #1512146
10/05/13 12:02 AM
10/05/13 12:02 AM
NE
O
O
NE
Idles good, does not run strong from quarter to full throttle, as said it seems sluggish. Its not missing or bogging. Set initial timing at 16 adv. Checked air gap on MP Distributor w/ orange box and installed. Hard to explain, been away from motors for a long time. Thanks
Re: AVS vacuum tube [Re: Oldstrtracr] #1512147
10/05/13 12:14 AM
10/05/13 12:14 AM
How far are you from Lincoln? All OE AVS's are lean (emission stds in those days were strict/alot of bandaid factory solutions were in use). Could you block the metering rods up so you are on the power circuit & retry it?
