727 Only Lurches Forward In Drive #1511726
10/02/13 09:53 PM
10/02/13 09:53 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
Bench rebuilt 727, it worked fine for a couple of hundred miles after I first installed it in the car, then it sat for awhile and now when I put it in drive, it just moves a couple of feet and that's it. It still has reverse though.
Please tell me it just needs a band adjustment?
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511727
10/02/13 11:02 PM
10/02/13 11:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
it needs a band adjustment ....
Sorry , the bands have nothing to do wit hit in first.
If you shift it to manual low will it drive ?
Re: 727 Only Lurches Forward In Drive [Re: JohnRR] #1511728
10/02/13 11:06 PM
10/02/13 11:06 PM
nope
doesn't reverse and 1st use the same band?
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511729
10/03/13 12:47 AM
10/03/13 12:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
nope
yes they do but band is only used in manual low , otherwise the rear sprag is doing the holding of the rear drum.
Your issue could be the rear clutch.
Re: 727 Only Lurches Forward In Drive [Re: JohnRR] #1511730
10/03/13 03:00 PM
10/03/13 03:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, rear clutch.
Re: 727 Only Lurches Forward In Drive [Re: John_Kunkel] #1511731
10/03/13 04:34 PM
10/03/13 04:34 PM
grrrr......
Is that a DITY job or am I sending it to a transmission guy? I know little about automatic transmissions beyond adjusting bands, valve bodys and basic maintenance.
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511732
10/03/13 04:36 PM
10/03/13 04:36 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Now's a perfect time to become acquainted with the inner-workings of a Torqueflite...
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511733
10/03/13 04:43 PM
10/03/13 04:43 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I really enjoyed rebuilding my 1st trans this year. Picked up a couple of widely read books & had at it. Only takes a few tools & some patience. Had a couple of small rookie issues but I saved a ton of dough & now have no concern rebuilding them in the future. The time/tools will pay for itself ten fold, IMHO.
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511734
10/03/13 06:06 PM
10/03/13 06:06 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
grrrr......
Get a factory service manual and tear into the transmission. It's really not that hard. I've done a few.
The only special tools you need are some snap ring pliers. It is a good idea to have a dial indicator to measure the end play on the shaft.
- Stu Harmon
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511735
10/03/13 06:43 PM
10/03/13 06:43 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
There's a lot of difference between a basic rebuild, and a full-boogie race unit...
What 'chu gonna do???
Gonna look at sprag options??? Play with line pressure???
Look at drum and band options??? 'Re-program' the shift-points???
It can be as wild, or as mild as you want it...
Re: 727 Only Lurches Forward In Drive [Re: RangerDan440] #1511736
10/04/13 12:31 AM
10/04/13 12:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you need a good set of snap ring pliers and a set of lock ring pliers for the lock ring on the bearing in the tailshaft.
lock ring pliers
Re: 727 Only Lurches Forward In Drive [Re: JohnRR] #1511737
10/04/13 02:09 AM
10/04/13 02:09 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and how about compressing the front drum to get the lip seals?
and removing and replacing bushing....at least the pump, front drum and tail bushings....
if you gotta do it..do it right....
forget the books...buy the video..
http://store.boxwrench.net/Chrysler-727-TorqueFlite-Transmission-Rebuild-DVD_p_70.html
Tony
70 AARCuda Vitamin C
Re: 727 Only Lurches Forward In Drive [Re: 70AARcuda] #1511738
10/04/13 09:15 AM
10/04/13 09:15 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
To compress the lip seal I use zipties and then use freez spray to cool it, works great.
Or you could zip tie it and put it in the freezer.
Just my
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: 727 Only Lurches Forward In Drive [Re: 70AARcuda] #1511739
10/04/13 10:01 AM
10/04/13 10:01 AM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
And having the proper size bushing drivers and a shop press makes this job a whole lot easier.
1979 AMC Spirit, NHRA Q/SA
Re: 727 Only Lurches Forward In Drive [Re: longram60] #1511740
10/04/13 10:28 AM
10/04/13 10:28 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I bought a $120 press & a $50 bushing driver kit for doing these. Makes changing out the bushings a breeze. A homemade adapter & you can press the front clutch retainer on with ease as well. Doing one trans yourself easily pays for all the tools.
Re: 727 Only Lurches Forward In Drive [Re: longram60] #1511741
10/04/13 10:50 AM
10/04/13 10:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I use my Lisle Cam bearing install tool to isnatall and remove these bushing .
another tool needed , or improvised , is one to compress the retainer for the springs on the front clutch.
