Re: 727 Only Lurches Forward In Drive
[Re: RangerDan440]
#1511727
10/02/13 11:02 PM
10/02/13 11:02 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
it needs a band adjustment .... Sorry , the bands have nothing to do wit hit in first. If you shift it to manual low will it drive ?
[Re: RangerDan440]
#1511729
10/03/13 12:47 AM
10/03/13 12:47 AM
JohnRR
U.S.S.A.
nope
doesn't reverse and 1st use the same band?
yes they do but band is only used in manual low , otherwise the rear sprag is doing the holding of the rear drum.
Your issue could be the rear clutch.
[Re: JohnRR]
#1511737
10/04/13 02:09 AM
10/04/13 02:09 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
and how about compressing the front drum to get the lip seals? and removing and replacing bushing....at least the pump, front drum and tail bushings.... if you gotta do it..do it right.... forget the books...buy the video.. http://store.boxwrench.net/Chrysler-727-TorqueFlite-Transmission-Rebuild-DVD_p_70.html
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1511738
10/04/13 09:15 AM
10/04/13 09:15 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
To compress the lip seal I use zipties and then use freez spray to cool it, works great. Or you could zip tie it and put it in the freezer. Just my
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
