69 Dart GTS tail panel clips #1511481
10/02/13 03:52 PM
10/02/13 03:52 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Anyone know of a good source? I'm not even sure how many I need. The trunk lid I have needs drilled.
Re: 69 Dart GTS tail panel clips [Re: mopfried] #1511482
10/02/13 08:03 PM
10/02/13 08:03 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Not an easy part to find, I hoard them with impunity! There are other clips that can be used but don't work as well as the originals.
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511483
10/08/13 07:36 AM
10/08/13 07:36 AM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Anyone else know of where I can find some? Im getting really close to paint and I don't want to have to drill and trial fit on new paint. Please help.
Re: 69 Dart GTS tail panel clips [Re: mopfried] #1511484
10/08/13 10:39 AM
10/08/13 10:39 AM
Rhinotruck
Rhinotruck
I have not found but a couple of the clips at this point. I did check two trunk lids and recorded the measurements, but of course it is more complicated to explain than I thought. I started from the left top corner and measured to the right. They are 1/4" holes and the first one starts 5/8" from the edge and 1-1/2" down. The next one down is 4-7/8". The top row from the first hole is 4-5/8", 9-3/4", 9-3/4", 9-3/4" and the last hole is also 5/8" from the top right edge with the hole below it at 4-7/8". The bottom row holes from the left bottom hole is 9-1/4", 7-3/4", 10-3/4", 7-3/4", and 7-3/4". Of course you can approximate and check the hole spacing by turning your panel over and reversing the dimensions. Not to worry, I was a Mechanical Designer in a previous lifetime and double-checked my findings. I will see if I can dig-up more of the clips.
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511485
10/08/13 01:29 PM
10/08/13 01:29 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Thanks for the info.... I have worked in the metal working industry for over 30 years... enough to know that
Mechanical Designer in a previous lifetime and double-checked my findings. Don't give me a lot of assurance!! lol just having fun... Really thanks a lot for that info. Let me know if you find some more clips. I did look at FOR A BODIES ONLY and found a link for some for a barracuda they say will work. I don't even know what the correct ones look like...
Heres the link.
http://www.buymetroparts.com/item/a-body/plymouth-rear-finish-panel-att/lid=18080013
Re: 69 Dart GTS tail panel clips [Re: mopfried] #1511486
10/08/13 03:18 PM
10/08/13 03:18 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
Re: 69 Dart GTS tail panel clips [Re: 68GTS383] #1511487
10/08/13 03:30 PM
10/08/13 03:30 PM
Columbus Ohio
mopfried Offline OP
mopfried  Offline OP
Columbus Ohio
Have you used them?
Re: 69 Dart GTS tail panel clips [Re: mopfried] #1511488
10/08/13 11:04 PM
10/08/13 11:04 PM
Rhinotruck
Rhinotruck
Heres the link.
69 Barracuda and Dart are the same clip, and equally as hard to find.
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: 68GTS383] #1511489
10/08/13 11:06 PM
10/08/13 11:06 PM
Rhinotruck
Rhinotruck
http://www.ebay.com/itm/121019447089?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
These are on ebay
They do look REAL close to the originals, but ALOT longer studs! At least there are 14 of them, the same number needed for you panel. Price is kinda high, but if you need them you need them.
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511490
10/09/13 06:12 AM
10/09/13 06:12 AM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
Original 69 Barracuda clips: 14 pieces #10-24 x 7/16. Pea soup green color, maybe an epoxy paint?
Came from the factory with 6 stamped sheet metal nuts on one side and 8 Huglok nuts with an internal nylon ring on the other side.
The stamped sheet metal nuts are the same as part B-12980 on page 69 here: http://www.amkproducts.com/Catalog_PDF/56-73.pdf
The holes in the trunk are notorious for water entry and trunk lid rusting. A formed donut of rope caulk in the depression of the sheet metal nuts will help make a seal.
Re: 69 Dart GTS tail panel clips [Re: kentj340] #1511491
10/09/13 11:00 AM
10/09/13 11:00 AM
Rhinotruck
Rhinotruck
Dart used 10 stamped steel nuts and 4 Huglok nuts for the ends.
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511492
10/09/13 09:06 PM
10/09/13 09:06 PM
Cut and Shoot, TX
Cut and Shoot, TX
Cool. I'll bet my Barracuda shoulda been like that but was obviously assembled on a Monday morning.
Not only that, but the factory didn't drill, didn't attach the "340-S" emblems to my front fenders. Took me quite a long time to find out they should have been there - nearly 40 years.
Re: 69 Dart GTS tail panel clips [Re: kentj340] #1511493
10/09/13 10:03 PM
10/09/13 10:03 PM
Rhinotruck
Rhinotruck
So you had A53 on your fender tag? In 69 they made 340 Barracuda's without being Formula S's.
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511494
10/10/13 01:36 AM
10/10/13 01:36 AM
Cut and Shoot, TX
Cut and Shoot, TX
Yep, I ordered the car with A53, and it's on my fender tag and window sticker, and I paid $132.00 for it ($186.30 MSRP).
The
"HIGH PERF. ENG./340 CID/,
DUAL EXHAUSTS & CHROME EXH. TIPS,
H.D. SUSP. PKG., FIRM RIDE SHOCK
ABS., RED STREAK TIRES, FORMULA S
MEDALLION, ENGINE PLAQUE, RADIATOR
GRILLE-BLACK, HD. WHEELS, REAR DECK
APPLIQUE-BLACK."
are all there (except I ordered white streak tires), but no front fender emblems, which were not listed in this A53 description. The 69 sales brochure only said, "...and Formula "S" body trim." So I never knew the emblems were missing until I started recently to restore the car and found out the emblems were for sale.
Re: 69 Dart GTS tail panel clips [Re: kentj340] #1511495
10/10/13 10:55 AM
10/10/13 10:55 AM
Rhinotruck
Rhinotruck
My 69 Dart GTS had a GT SPORT stripe on one side and a DART SWINGER stripe on the other, so I am not surprised!
A-Body's RULE!
Re: 69 Dart GTS tail panel clips [Re: Rhinodart] #1511496
10/10/13 12:08 PM
10/10/13 12:08 PM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
There is currently one on the Seattle CL. Maybe he would be willing to seperate what you need unless you wanted the whole thing. Search using Dart GTS or the heading in his ad is Mopar Parts and Goodies. Saw it quickly when he was unloading a 340 for me and it didn't look bad. He also had the hood, doors and some other pieces. Hope this helps.
