Stamps/Stencils for diff. part marking #1510821
10/01/13 04:45 PM
10/01/13 04:45 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
When it comes to marking the rear carrier housing all alpha or alpha numeric characters I have seen look stamped. Does anyone make a large character (7/8) stamp with a good font that is adjustable that would work for this application?
Re: Stamps/Stencils for diff. part marking [Re: 70mopes] #1510822
10/01/13 05:11 PM
10/01/13 05:11 PM
MA
steve70 Offline
steve70  Offline
MA
1970 Challenger T/A 4 speed
Re: Stamps/Stencils for diff. part marking [Re: 70mopes] #1510823
10/01/13 08:37 PM
10/01/13 08:37 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If you want it exact take a pic,clean it up with a photoshop if needed... Then take the pic to a stamp/stencil shop and they'll make a stamp of the pic you've submitted... I do this and it's relatively cheap...
Re: Stamps/Stencils for diff. part marking [Re: screamindriver] #1510824
10/01/13 09:36 PM
10/01/13 09:36 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Clean the housing and use tracing paper. Then transfer to heavier paper, cut out and spray! Thats' what I did with my transmission.
Admiration For Multiple Carburetor Vehicles...
Re: Stamps/Stencils for diff. part marking [Re: 70mopes] #1510825
10/03/13 01:12 AM
10/03/13 01:12 AM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Just qurious,how do you read out a date code like this? What does the x mean?
THANKS
Nicklas
Re: Stamps/Stencils for diff. part marking [Re: 71redcuda] #1510826
10/03/13 12:50 PM
10/03/13 12:50 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Feb 16th assy date of the rear axle assy. My SPD is 2/26. The stamp was probably adustable and would have to have 4 digits to cover all month and day variations. The 'X' may simply be a place holder or could have significance beyond that.
Re: Stamps/Stencils for diff. part marking [Re: 70mopes] #1510827
10/04/13 01:42 AM
10/04/13 01:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Other photos posted here have shown these stencils:
Housing, "9-14U". Pig, "9-14".
Housing, "5-12Z". Pig, ?
Housing, "2-16X". Pig, ? SPD 2/26.
Housing, "...1L". Pig, "10-23". Hamtramck. SPD 11/8/68.
If anyone else can contribute to this list, please do.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510828
10/04/13 09:55 AM
10/04/13 09:55 AM
pa.
dan9 Offline
dan9  Offline
pa.
These aren't very clear at least to me but this is what i found on a 70 Challenger.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510829
10/04/13 10:05 AM
10/04/13 10:05 AM
pa.
dan9 Offline
dan9  Offline
pa.
another
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510830
10/04/13 10:07 AM
10/04/13 10:07 AM
pa.
dan9 Offline
dan9  Offline
pa.
third
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510831
10/04/13 10:08 AM
10/04/13 10:08 AM
pa.
dan9 Offline
dan9  Offline
pa.
fourth
Re: Stamps/Stencils for diff. part marking [Re: dan9] #1510832
10/10/13 01:07 AM
10/10/13 01:07 AM
Il
1ol74charger4me Offline
Il
74 charger. May not be correct rearend.
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510833
10/10/13 01:13 AM
10/10/13 01:13 AM
Il
Il
another
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510834
10/10/13 02:31 AM
10/10/13 02:31 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Updating the list.
Housing, "101G". Pig, ?
Housing, "J128". Pig, ?
Housing, "19U". Pig, ?
I think there is a correlation between the housing date and the pig date. Maybe same date or close.
Most stencils have more paint at the edges of the characters than the middle. Wonder what causes that?
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510835
10/10/13 10:01 AM
10/10/13 10:01 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Based on the appearance of these stamps it appears they were some sort of soft stamp material, likely rubber, not "stencils". Rubber stamps "squish" when you press them, often pushing the paint to the outsides and leaving the center thin or nearly void of paint, It all depends on the pressure applied when adding them. MOST stampings that are added back by restorers are too perfect because of the extra effort making them nice.
Re: Stamps/Stencils for diff. part marking [Re: kentj340] #1510836
10/11/13 03:47 AM
10/11/13 03:47 AM
Il
Il
Updating the list.
Housing, "19U". Pig, ? should be 190, I had went over it with paint pen to get a size picture of it, pig was a 67 and no markings
Re: Stamps/Stencils for diff. part marking [Re: 1ol74charger4me] #1510837
10/11/13 01:10 PM
10/11/13 01:10 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
My '69 roadrunner had it's orginal housing and 8 3/4. The 8 3/4 sure-grip was dated 4/22. The housing was dated the next day - 4/23.
Re: Stamps/Stencils for diff. part marking [Re: 70mopes] #1510838
10/11/13 02:14 PM
10/11/13 02:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I finshed an 8.3/4 for a 1969 Charger this spring and the dates were nearly a week apart.
I had a stamp made at rubberstampchamp.com to redo them
Re: Stamps/Stencils for diff. part marking [Re: gtx6970] #1510839
10/11/13 02:15 PM
10/11/13 02:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: Stamps/Stencils for diff. part marking [Re: gtx6970] #1510840
10/11/13 02:17 PM
10/11/13 02:17 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
axle markings
