FRAM CA-305 air filter - original - pictures #1509893
09/30/13 10:11 AM
09/30/13 10:11 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
All this discussion on FRAM air filters...
I thought that I would post pictures of my original 1970 340 air filter.
Ola
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509894
09/30/13 10:11 AM
09/30/13 10:11 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
2
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509895
09/30/13 10:11 AM
09/30/13 10:11 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
3
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509896
09/30/13 10:11 AM
09/30/13 10:11 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509897
09/30/13 10:12 AM
09/30/13 10:12 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509898
09/30/13 10:12 AM
09/30/13 10:12 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509899
09/30/13 10:12 AM
09/30/13 10:12 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509900
09/30/13 10:12 AM
09/30/13 10:12 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
8
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509901
09/30/13 10:13 AM
09/30/13 10:13 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
9
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509902
09/30/13 10:13 AM
09/30/13 10:13 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
10
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509903
09/30/13 10:13 AM
09/30/13 10:13 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
11
Re: FRAM CA-305 air filter 340 [Re: cudaized] #1509904
09/30/13 10:14 AM
09/30/13 10:14 AM
South, FL
cudaized Offline OP
cudaized  Offline OP
South, FL
12
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
ebodyconvertibleregistry.com
Re: FRAM CA-305 air filter - original - pictures [Re: cudaized] #1509905
09/30/13 11:09 PM
09/30/13 11:09 PM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
Good pictures.
I recently picked up a NOS one, and also bought the current 305 offering from Fram.
Biggest differences that I can tell is the part number is molded into the rubber seal on the original. Also, the little recesses molded in the rubber seal are round on the original, and rectangular on the current offering.
Re: FRAM CA-305 air filter - original - pictures [Re: bill440rt] #1509906
09/30/13 11:20 PM
09/30/13 11:20 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Nice... So are the holes flat or punched with a lip? looks like both. Folded seam is a nice touch.
Re: FRAM CA-305 air filter - original - pictures [Re: 135sohc] #1509907
09/30/13 11:56 PM
09/30/13 11:56 PM
N
NMSEd Offline
NMSEd  Offline
N
The reason it looks like both is that what you are seeing is an excellent example of the "burr" that developed when the punch die started to dull. The tooling was then switched from a flat hole punch to a Dimpled punch to raise this "burr" away from the media and avoid the possibility of the burr side (if the band was assembled with the burr side towards the filter media) coming into contact and chafing the filter media. The Dimpled holes then created an unmistakable marking of which side of the band was the outside during the assembly process.
NMS Performance Products www.nmsperformance.net
Re: FRAM CA-305 air filter - original - pictures [Re: NMSEd] #1509908
10/01/13 02:05 AM
10/01/13 02:05 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
How fast did the die dulling occur? I've seen 100% production line original A12 filters with the flared holes, this was one of the first applications for these filters. I've seen s good number of original 69-71 cars that still had the original filters (survivors) and I've never seen one example with the flat screen holes. Not saying they didn't exist but they seem to be the exception, or rarity, not the rule or norm, accordingly I'd prefer having one with the flares. Can you make that style?
Re: FRAM CA-305 air filter - original - pictures [Re: ScottSmith_Harms] #1509909
10/01/13 08:16 AM
10/01/13 08:16 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Ed
Did you work for Fram in Providence, Rhode Island.
I was under the impression that the filters were manufactured there for some time and at the sister company in Stratford, Ontario, Canada.
I know for a fact the Stratford facility manufactured the oval filters in the 60's.
Therefore there must have been two sets of tooling, one in Canada, one in the US.
Would that offer any accounting for the flared and non flared or did they wear at the same rate depending on production.
Re: FRAM CA-305 air filter - original - pictures [Re: mccannix] #1509910
10/01/13 10:12 AM
10/01/13 10:12 AM
N
NMSEd Offline
NMSEd  Offline
N
Ed
Yes, I was born and raised in RI and that is where I started working with FRAM. Moved to Ohio in the 90's when the Engineering Department was moved to Perrysburg OH.
The prototype and the original production of the Six Pack Filter began in Providence, I built the prototype myself. Eventually the parts came from any one of 4 different plants in the US and Canada. This part was a low production piece, most of the time it was manufactured in East Providence RI or Ontario, But it depended on where the inventory was needed and production line availablity. It was made in Stratford Ontario Canada, Greenville Ohio, or Clearfield UT as well as the Providence location (actually East Providence). So there was tooling in each location. The tooling was not changed all at once in the beginning, but eventually it was all changed to the dimple screen to avoid the burr issue. This fact is the reason there are parts with either/or for a period of time depending on whether the run was made "online" or in an "off-line" batch, and which plant produced the batch.
Hope that answers the question, I need to load up on more coffee to fully wake up so I may tweak the answer once Im fully alert
Ed
Re: FRAM CA-305 air filter - original - pictures [Re: NMSEd] #1509911
10/01/13 11:36 AM
10/01/13 11:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That makes sense. Coincidentally I worked in the same building in Clearfield Utah for 7 years, it was in the Freeport Center and was owned by Allied Signal (formerly Fram).
Re: FRAM CA-305 air filter - original - pictures [Re: ScottSmith_Harms] #1509912
10/01/13 10:54 PM
10/01/13 10:54 PM
New Jersey Bada Bing
bremotorsports Offline
I have 3 CA-305's on hand:
Example 1 Mopar Box/Puckered Screen/Fram CA-305 NOT molded into rubber.
Example 2 Fram Box/Puckered Screen/Fram CA-305 molded into rubber.
Example 3 Fram Box/Flat Screen/Fram CA-305 molded into rubber.
Most, but not all, original production filters have NOT had the Fram CA-305 molded in.
Bill Rolik
