Electric choke for LD340 #1509266
09/28/13 08:55 PM
09/28/13 08:55 PM
Worcester, Mass
68goldfish Offline OP
Worcester, Mass
Hi,
I have a LD340 Intake that I plan on using with the stock Carter carb. This intake does not have a pot for the stock choke. Could I adapt a 225 Electric choke Holley #400669 for this combo? Thanks!
Re: Electric choke for LD340 [Re: 68goldfish] #1509267
09/28/13 09:39 PM
09/28/13 09:39 PM
On your six o'clock
B7Satellite Offline
B7Satellite  Offline
On your six o'clock
Most of the LD340s that have the Chrysler part number cast into them also have this pad cast onto the exhaust crossover. The pad is for a GM choke thermostat. If the intake does not have the Chrysler part number cast into it then it usually does not have the choke pad. Edelbrock sells their version of the choke thermostat but you can also get one from any auto parts store cheaper. If you have that pad on your intake let me know and I'll see if I can find the part number for the choke.
Re: Electric choke for LD340 [Re: B7Satellite] #1509268
09/28/13 09:40 PM
09/28/13 09:40 PM
On your six o'clock
B7Satellite Offline
B7Satellite  Offline
On your six o'clock
close up
Re: Electric choke for LD340 [Re: B7Satellite] #1509269
09/28/13 09:47 PM
09/28/13 09:47 PM
On your six o'clock
B7Satellite Offline
B7Satellite  Offline
On your six o'clock
No Chrysler part number, no choke pad (usually).
Re: Electric choke for LD340 [Re: B7Satellite] #1509270
09/29/13 11:33 AM
09/29/13 11:33 AM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hello I have two LB4B intakes they have choke pads and I have one that is a LD340 with out a part number and no Choke pad also .
