Strange 2-Bbl Action Today #1508011
09/26/13 05:22 PM
09/26/13 05:22 PM
Mid TN
2BblHarold Offline OP
Mid TN
I had a no start situation after a long garage rest for my Coronet, 318 2 Bbl. I determined the carb was not getting gas. When I disconnected the fuel line at the filter, it came off with a POP, and then the normal spillage out the filter. So the gas was making it past the pump. I took the top off the carb to expose the bowl, and it was bone dry. I manipulated the acc pump, floats, and the metering rod (I think) just to make sure things were moving. I put a little gas in the bowl, reassembled, and it fired right up. Here, I left the fuel filter OFF to eliminate it as a problem. Ran just fine for 10 minutes, and I shut it down. Next, I hear a hissing coming from the carb, and looking closely, I can see gas running out what seemed like every orifice of the carb! It was enough to drench the intake, and puddles were forming. Atop the intake, it was hot enough to bubble, so I backed off quick-like. I grabbed a towel to either wrap around my soon to be on fire head or fan off the heat from the engine. Fortunately, no disaster ensued.
I'm suspicious of the POP when I disconnected the line, and all that hissing and fuel barfing at the end has me puzzled. Perhaps a cracked bowl? But why all the hissing?
I'm thinking I'm retiring the 2 Bbl setup here, so I'm not going to knock myself out on solving this. But I am curious if anyone has any thoughts on this.
Thanks!
Re: Strange 2-Bbl Action Today [Re: 2BblHarold] #1508012
09/26/13 05:32 PM
09/26/13 05:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
"Long garage rest". I suspect a possibility of the needle sticking to seat, causing the pop you witnessed when removing line. I would invest in a decent carb kit to overhaul that carb. Now that the needle is free, it may have some crud around it so it can't seat.
Re: Strange 2-Bbl Action Today [Re: buildanother] #1508013
09/26/13 05:36 PM
09/26/13 05:36 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, fuel purging from every orifice is an over full bowl for sure, stuck open needle/seat, stuck, sunk, or misadjusted float, etc.
Re: Strange 2-Bbl Action Today [Re: buildanother] #1508014
09/26/13 05:36 PM
09/26/13 05:36 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Needle not seating. When working correctly the float rises to push the needle against the seat cutting off the gas. If there is crap between the needle and the seat it can't close letting the carb overflow.
Re: Strange 2-Bbl Action Today [Re: stumpy] #1508015
09/26/13 05:53 PM
09/26/13 05:53 PM
Mid TN
Mid TN
Sounds good. I did manipulate the needle during all this, and it was stuck. So now it seems to be unstuck, but not seating. Thanks for the brains!
Re: Strange 2-Bbl Action Today [Re: 2BblHarold] #1508016
09/26/13 05:59 PM
09/26/13 05:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Needles and seats are quite delicate. Could be swollen shrunk, or generally degraded from todays methanol laced fuel, could be glazed over with old fuel varnish, could be that you damaged it playing with it, etc. Have you rechecked your float adjustment?
Re: Strange 2-Bbl Action Today [Re: ScottSmith_Harms] #1508017
09/26/13 06:09 PM
09/26/13 06:09 PM
Mid TN
Mid TN
No Scott, not from the rebuild I did several years ago. I don't recall how to achieve the baseline setting?
Re: Strange 2-Bbl Action Today [Re: 2BblHarold] #1508018
09/26/13 06:48 PM
09/26/13 06:48 PM
As said the needle stuck from non use then it flooded possibly from minute debris that dried out on the contact surface. I'd spray the seat clean with brake kleen and wipe the needle between your thumb/forefinger to clean/smooth it then see if the neoprene taper has a groove & if not you might try to reuse it & good chance you'll be fine. Since it is a Carter you might be able to buy the needle/seat seperately for it or take it to an O'reillys that stocks (or can order) a needle/seat for Eddy performer carbs & see if it is the same. Worst case you could buy a new kit specifically for the 2bbl & use just the needle/seat (for now/complete rebuild later as needed) & be up & running in no time. Do check/reset the float level if needed
Re: Strange 2-Bbl Action Today [Re: RapidRobert] #1508019
09/26/13 11:28 PM
09/26/13 11:28 PM
Mid TN
Mid TN
Cleaned it all out. Yes, the needle was a bit gunked. I was also suspicious of the c-clip that holds the float assembly in place. Seems like the float was getting hung up sometimes because the clip had a poor fit. I reshaped it, closed it up, and manipulated the float with a screwdriver through the fuel inlet, just to ensure it was moving freely. All went well on the next start up and shut down. The 2 Bbl might have more life! Thanks!
Re: Strange 2-Bbl Action Today [Re: 2BblHarold] #1508020
09/27/13 10:17 AM
09/27/13 10:17 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would hope so or you'd need to change your user name on here
