71 Challenger head light bezel install #1507673
09/25/13 08:46 PM
09/25/13 08:46 PM
Mn, USA
3
340ShakerR/T Offline OP
Mn, USA
Hey guys, I am finally installing my grille and headlight bezels on my chally. The bezels where not on the car when I purchased it and I do not have any of the screws and clips to install them. Does anyone know where I can get all of the clips and screws? Thanks.
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507674
09/25/13 09:03 PM
09/25/13 09:03 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507675
09/26/13 10:00 AM
09/26/13 10:00 AM
Mn, USA
3
Mn, USA
OK, great! Thanks. Are there some kind of clips that attach on the fender lip? Or is the screw supposed to go directly into the fender? The holes look too big for just screws.
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507676
09/26/13 10:06 AM
09/26/13 10:06 AM
N.E. Ohio
K
KillerBee Online content
KillerBee  Online Content
K
N.E. Ohio
There are clips that slide on the tabs on the fenders that the screws go through.
There are 2 1971 Challenger grill hardware kits, one for R/T models and one for non R/T model.
I had trouble with the plastic inserts(bag #5 in picture) that slide into the slotted ends of the center grill and the headlight bezels screw into.
They didn't look like the original ones I took off and I couldn't get them to work so I reused the factory ones.
Here is the R/T kit
http://www.ebay.com/itm/Mopar-71-Challen...d76&vxp=mtr
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507677
09/26/13 10:13 AM
09/26/13 10:13 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
On the fender, there are 3 clips per fender IIRC. Then, there are to the 4 sliding nut plates that slide into the grille ) 2 per side. These are the anchor points for the two inboard screws. Now, I had to massage the sliding clips a wee bit so they would slide into the grille grooves..
Inboard bezel attach points: 71 Challenger thread of mine
I have attached a picture of the grille attach hardware kit. You will notice the 6 clip/screw pairs ( those go in the fenders )
Troy
Houston Mopar Connection Club
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507678
09/26/13 10:18 AM
09/26/13 10:18 AM
Mn, USA
3
Mn, USA
PERFECT! Thanks guys. I'll get some coming.
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507679
10/01/13 04:07 PM
10/01/13 04:07 PM
Mn, USA
3
Mn, USA
Got the parts, I did have to work the plastic nuts that slide into the grille. I did manageto get them to work. Now I have to ask, what is the best way to instll the 5 large plastic push in fasteners that hold the top of the grille in place? They push in pretty hard!
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507680
10/01/13 04:44 PM
10/01/13 04:44 PM
N.E. Ohio
K
K
N.E. Ohio
I had to lightly crush the christmas tree end with pliers to get them to fit.
Trial and error, don't get carried away.
Re: 71 Challenger head light bezel install [Re: KillerBee] #1507681
10/01/13 06:04 PM
10/01/13 06:04 PM
Houston, Tx
Houston, Tx
Yes, don't push the issue too hard...... The holes might be smaller due to paint? The buttons pushed in rather nice ( and firm ), on Hoss' '71.
Good Luck
Troy
Re: 71 Challenger head light bezel install [Re: 340ShakerR/T] #1507682
10/06/13 01:59 PM
10/06/13 01:59 PM
Mn, USA
3
Mn, USA
Got the grille and headlight bezels installed! Looks awesome. I warmed up the christmas trees in warm water, sprayed a shot of pledge on them and popped them right in. Thanks for the help.
