Re: Engine Oil Changing - Time vs. Miles?
[Re: dogdays]
#1507404
09/25/13 11:27 PM
09/25/13 11:27 PM
Challenger 1
Cincinnati, Ohio
Just for grins, do an oil analysis the next time you change you oil. I'm sure you'll be told it's okay, meets all specifications. We waste a lot of perfectly good oil by ideas or habits driven by fear. R.
[Re: dogdays]
#1507407
09/26/13 09:19 AM
09/26/13 09:19 AM
Andrewh
lol, but if you look at the price for that check vs an oil change, it can be cheaper for the oil change.
it is one thing to have a diesel that holds like 20 qt, but 4 to 6 at 35 bucks, or worse if you use conventional at 10 bucks with an analysis running 25- 35, you might as well change it.
[Re: Andrewh]
#1507408
09/26/13 10:04 AM
09/26/13 10:04 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
On an older muscle car I also do a sniff test. If the oil smells like gas it gets changed.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Andrewh]
#1507409
09/26/13 12:18 PM
09/26/13 12:18 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
You do one analysis. If it comes back and says 'oil is good, clean, still meets spec, pH normal, etc, then you bump out your change interval. Do it again.
Repeat until analysis finally says 'oil is out of spec' then you know what interval to change, and you don't buy any more analysis.
You don't do an analysis every time to determine if its time to change or not
**Photobucket sucks**
[Re: Plum440]
#1507410
09/26/13 02:07 PM
09/26/13 02:07 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
If you only put about 25 - 50 miles per month (if that) on your car, how often do you change the oil? Once a year? Every 6 months?
SHORT HOPS ... typically referred-to as grocery-store miles ... never actually getting the oil completely warm/HOT ... it needs to be changed BIG TIME often...
