Engine Oil Changing - Time vs. Miles? #1507395
09/25/13 11:47 AM
09/25/13 11:47 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
If you only put about 25 - 50 miles per month (if that) on your car, how often do you change the oil? Once a year? Every 6 months?
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Engine Oil Changing - Time vs. Miles? [Re: Plum440] #1507396
09/25/13 11:49 AM
09/25/13 11:49 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I would think some of that would depend on humidity of the area and where the car is stored. I put 500 miles on my Durango in the last three months. I'm not about to change the oil as it gets driven every week day. I'll let it go at least six months.
Re: Engine Oil Changing - Time vs. Miles? [Re: Jim_Lusk] #1507397
09/25/13 12:05 PM
09/25/13 12:05 PM
Andrewh Offline
Andrewh  Offline
pretty much once a year.
none of my cars hit the mileage for changing anymore.
some of them I change specifically because they don't get driven far enough during the drives I do have.
my mopar gets driven maybe 2k miles a year.
my DD gets maybe 1k a year.
wife's car gets maybe 8k.
all running full synthetic.
all get changed yearly. or close enough.
Re: Engine Oil Changing - Time vs. Miles? [Re: Andrewh] #1507398
09/25/13 12:28 PM
09/25/13 12:28 PM
dogdays Offline
dogdays  Offline
Just for grins, do an oil analysis the next time you change you oil. I'm sure you'll be told it's okay, meets all specifications.
We waste a lot of perfectly good oil by ideas or habits driven by fear.
R.
Re: Engine Oil Changing - Time vs. Miles? [Re: dogdays] #1507399
09/25/13 12:51 PM
09/25/13 12:51 PM
BDW Online content
BDW  Online Content
As TTI puts in their exhaust instructions, I agree, it's worse to do short drives that never get engine hot enough to burn off condensation.
Re: Engine Oil Changing - Time vs. Miles? [Re: BDW] #1507400
09/25/13 12:54 PM
09/25/13 12:54 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Change it annually if you don't meet the mileage interval. Right before storage is a great time.
Re: Engine Oil Changing - Time vs. Miles? [Re: Aero426] #1507401
09/25/13 02:39 PM
09/25/13 02:39 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thanks guys! Once a year makes sense to me. Good idea on the oil analysis...
A couple of Jeeps…
Re: Engine Oil Changing - Time vs. Miles? [Re: Plum440] #1507402
09/25/13 10:23 PM
09/25/13 10:23 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
About every 20-25 hits at the track....oil goes a little dark then. Nothing like clean oil to make peace with the mind.
Re: Engine Oil Changing - Time vs. Miles? [Re: superwrench] #1507403
09/25/13 10:40 PM
09/25/13 10:40 PM
4X yearly on a DD (non synthetic). I'm sure good oil (especially synthetics) these days have far superior qualities but it's the buildup of contaminates that I want out of there & to me that's what wears the eng no matter how good the lube & other qualities of the oil are. It's pricey & maybe a waste (I ain't convinced tho) but I take no chances with all my thousands of time/money invested & I SLEEP better
Re: Engine Oil Changing - Time vs. Miles? [Re: dogdays] #1507404
09/25/13 11:27 PM
09/25/13 11:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
R.
Re: Engine Oil Changing - Time vs. Miles? [Re: Challenger 1] #1507405
09/25/13 11:39 PM
09/25/13 11:39 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Cheap peace of mind.
Careful, your character's showing!
Re: Engine Oil Changing - Time vs. Miles? [Re: mopar346] #1507406
09/26/13 03:19 AM
09/26/13 03:19 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
my two mopars average less than 1K a year each so i change before winter storage once a year
Re: Engine Oil Changing - Time vs. Miles? [Re: dogdays] #1507407
09/26/13 09:19 AM
09/26/13 09:19 AM
Andrewh Offline
Andrewh  Offline
R.
lol, but if you look at the price for that check vs an oil change, it can be cheaper for the oil change.
it is one thing to have a diesel that holds like 20 qt, but 4 to 6 at 35 bucks, or worse if you use conventional at 10 bucks with an analysis running 25- 35, you might as well change it.
Re: Engine Oil Changing - Time vs. Miles? [Re: Andrewh] #1507408
09/26/13 10:04 AM
09/26/13 10:04 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
On an older muscle car I also do a sniff test. If the oil smells like gas it gets changed.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Engine Oil Changing - Time vs. Miles? [Re: Andrewh] #1507409
09/26/13 12:18 PM
09/26/13 12:18 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
R.
You do one analysis. If it comes back and says 'oil is good, clean, still meets spec, pH normal, etc, then you bump out your change interval. Do it again.
Repeat until analysis finally says 'oil is out of spec' then you know what interval to change, and you don't buy any more analysis.
You don't do an analysis every time to determine if its time to change or not
**Photobucket sucks**
Re: Engine Oil Changing - Time vs. Miles? [Re: Plum440] #1507410
09/26/13 02:07 PM
09/26/13 02:07 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
SHORT HOPS ... typically referred-to as grocery-store miles ... never actually getting the oil completely warm/HOT ... it needs to be changed BIG TIME often...
