new gas tank,paint or clear coat? #1505025
09/20/13 07:41 PM
09/20/13 07:41 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
got a new, overdue, tank for the duster.what is correct paint?flat black?
Re: new gas tank,paint or clear coat? [Re: mcmopars] #1505026
09/20/13 07:52 PM
09/20/13 07:52 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
I clear coat mine, most straps are silver too.
Re: new gas tank,paint or clear coat? [Re: Dan Halen] #1505027
09/20/13 08:04 PM
09/20/13 08:04 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
No coating of any kind is needed.
Re: new gas tank,paint or clear coat? [Re: mcmopars] #1505028
09/20/13 08:40 PM
09/20/13 08:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Gas tanks were not painted when installed by the factory so what is your definition of CORRECT , anything other than installing it the way you pulled it from the box is not correct ... ASSuMEing you are doing a RESTORATION
Re: new gas tank,paint or clear coat? [Re: JohnRR] #1505029
09/20/13 08:51 PM
09/20/13 08:51 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Tanks were hot galvanized like the ones Spectra carries, not painted like the ones that Vans carries.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: new gas tank,paint or clear coat? [Re: moparmarks] #1505030
09/21/13 01:47 AM
09/21/13 01:47 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Yes, hot dipped, but not actually galvanized, which means hot dipped in zinc. Tanks were made from terne sheet which is steel sheet hot dipped in lead/tin. Lead/tin is the same as solder.
"This specification covers sheet steel in coils and cut lengths coated with lead-tin alloy (terne metal, see 3.2.3) by the hot-dip process. This material is commonly known as terne and is used where ease of solderability and a degree of corrosion resistance are desirable. It is especially suitable where resistance to gasoline is required..." From http://www.astm.org/Standards/A308.htm
Tank halves were heated at the flanges to make a soldered joint, same as is now done with the Spectra tanks. Since solder does not rust, there was no need for any coating by the factory. Old tanks eventually rust when long exposure to condensed moisture compromises the solder and exposes the steel underneath.
Tanks left the factory unpainted, but usually with some undercoating overspray even though only the wheel wells were undercoated and the whole bottom was not.
In time, lead/tin or solder will darken from exposure to the atmosphere, so some kind of coating like clear spray or RPM may help a restorer keep the original, shiny look. But there might be some adhesion issues with clear spray on solder.
Re: new gas tank,paint or clear coat? [Re: kentj340] #1505031
09/21/13 01:59 AM
09/21/13 01:59 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I coated mine with ECS's RPM, invisible once applied and protects against corrosion.
Re: new gas tank,paint or clear coat? [Re: ScottSmith_Harms] #1505032
09/21/13 08:45 AM
09/21/13 08:45 AM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
scott,thats the look im looking for,thanks
Re: new gas tank,paint or clear coat? [Re: ScottSmith_Harms] #1505033
09/21/13 01:11 PM
09/21/13 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Scott , I'm surprised to see that tank in there ...
Re: new gas tank,paint or clear coat? [Re: JohnRR] #1505034
09/21/13 01:34 PM
09/21/13 01:34 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well then this might not surprise you. After a 10 year search I finally found an NOS one, 1 day to the hour after I installed and undercoated the (only available AND also INCORRECT reproduction ) in the pic
*I may or may not install it now, as long as I have it safely stashed it's a no big deal down the road swap out.
