Re: new gas tank,paint or clear coat?
[Re: mcmopars]
#1505028
09/20/13 08:40 PM
09/20/13 08:40 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
got a new, overdue, tank for the duster.what is correct paint?flat black?
Gas tanks were not painted when installed by the factory so what is your definition of CORRECT , anything other than installing it the way you pulled it from the box is not correct ... ASSuMEing you are doing a RESTORATION
[Re: JohnRR]
#1505029
09/20/13 08:51 PM
09/20/13 08:51 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Tanks were hot galvanized like the ones Spectra carries, not painted like the ones that Vans carries.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1505030
09/21/13 01:47 AM
09/21/13 01:47 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Yes, hot dipped, but not actually galvanized, which means hot dipped in zinc. Tanks were made from terne sheet which is steel sheet hot dipped in lead/tin. Lead/tin is the same as solder. "This specification covers sheet steel in coils and cut lengths coated with lead-tin alloy (terne metal, see 3.2.3) by the hot-dip process. This material is commonly known as terne and is used where ease of solderability and a degree of corrosion resistance are desirable. It is especially suitable where resistance to gasoline is required..." From http://www.astm.org/Standards/A308.htmTank halves were heated at the flanges to make a soldered joint, same as is now done with the Spectra tanks. Since solder does not rust, there was no need for any coating by the factory. Old tanks eventually rust when long exposure to condensed moisture compromises the solder and exposes the steel underneath. Tanks left the factory unpainted, but usually with some undercoating overspray even though only the wheel wells were undercoated and the whole bottom was not. In time, lead/tin or solder will darken from exposure to the atmosphere, so some kind of coating like clear spray or RPM may help a restorer keep the original, shiny look. But there might be some adhesion issues with clear spray on solder.
[Re: ScottSmith_Harms]
#1505032
09/21/13 08:45 AM
09/21/13 08:45 AM
Posts: 1,012 indiana
mcmopars
indiana
I coated mine with ECS's RPM, invisible once applied and protects against corrosion.
scott,thats the look im looking for,thanks
#1505033
09/21/13 01:11 PM
09/21/13 01:11 PM
JohnRR
U.S.S.A.
Scott , I'm surprised to see that tank in there ...
