blinkers #1504479
09/19/13 03:25 PM
09/19/13 03:25 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
I can't figure out the prob here. When I put on the left blinker it works fine untill I step on the brake, then it stays on and wont blink untill I let off the brake. Any suggestions as to what to look for? Thanks, Clay
Re: blinkers [Re: Clayton] #1504480
09/19/13 05:39 PM
09/19/13 05:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Turn signal switch is hosed or the wiring is hacked. The high filament (IE turn/ brake) gets its power from the TS switch.
The TS switch controls which power source feeds it meaning 1 input lead from the flasher and another from the brake light switch.
So it sounds as though the brake switch signal is shorted to the Flasher output on the LR output.
Also make sure the 4 way flasher switch is off as it can cause some screwy things to happen
Re: blinkers [Re: TJP] #1504481
09/19/13 06:16 PM
09/19/13 06:16 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: blinkers [Re: 340SHORTY] #1504482
09/19/13 06:20 PM
09/19/13 06:20 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Your wrong.......he "blinker fluid" is below the minimum level.
Re: blinkers [Re: 67vertman] #1504483
09/19/13 09:07 PM
09/19/13 09:07 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
I'm not sure about the signal switch but the plug from the colum and the fuse box has been cut by the previous owner and barreled together...It's been fine for going on 10 years and just recently started this so I'm wondering why. I know very little about wiring but everything else I can see looks ok. Ive never been inside a colum befor and it doesnt look fun...Hate to think about replacing the signal switch if thats it.
Re: blinkers [Re: Clayton] #1504484
09/19/13 09:22 PM
09/19/13 09:22 PM
seperate the ts/brake harness under the steering column & ohm the wires to the TS switch. With the stalk in neutral there should be continuity between the white "in" wire from the brake light switch and 2 of the "out" wires to the pass/dr rear large filaments. Turn the stalk up & down & see what changes on the continuities. www.mymopar.com has the colors for you
Re: blinkers [Re: RapidRobert] #1504485
09/19/13 09:26 PM
09/19/13 09:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
check 4 bad grounds
I am truckless..
Re: blinkers [Re: 340SHORTY] #1504486
09/20/13 01:16 AM
09/20/13 01:16 AM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Boy do I feel dumb....The flasher switch was on and I didn't know it cause they don't flash. Turned it of and no more prob with the turn signal when I hit the brake! Doesn't make any sense to me but I'm sure glad it works:)
Re: blinkers [Re: Clayton] #1504487
09/20/13 11:17 AM
09/20/13 11:17 AM
success! & you didn't have to mess with any wiring . With the hazards not working it would be easy to have missed that they were on
Re: blinkers [Re: RapidRobert] #1504488
09/22/13 09:51 PM
09/22/13 09:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you replaced the hazzard flasher? There is one flasher for the turn signals and another for the hazzards.
Re: blinkers [Re: stumpy] #1504489
09/23/13 11:52 AM
09/23/13 11:52 AM
Yeah you might get off easy 2 times here
