Page 1 of 3 1 2 3
INDY 360-1 SPARK ADVANCE ? #1504272
09/19/13 11:43 AM
09/19/13 11:43 AM
AUSTRALIA
CLEVO351 Offline OP
CLEVO351  Offline OP
AUSTRALIA
How much timing does the Indy 360-1 head like with flat top and .040 quench 11.7 to 1 comp on 95 octane, what are your expirences on the dyno.? Do they like projected or regular spark plugs?
Re: INDY 360-1 SPARK ADVANCE ? [Re: CLEVO351] #1504273
09/19/13 12:28 PM
09/19/13 12:28 PM
Delray beach, Florida
P
Performance Only Offline
P
Timing will depend on other factors you haven't mentioned, but typically we find they like about 33 degree's total. I use NGK non-projected tips in a heat range compatible with the application. I'd start out with a -7 plug on a street car.
machine shop owner and engine builder
Re: INDY 360-1 SPARK ADVANCE ? [Re: CLEVO351] #1504274
09/19/13 12:28 PM
09/19/13 12:28 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Best power on pump gas on my engine masters Indy 360-2 was 42*
Re: INDY 360-1 SPARK ADVANCE ? [Re: Performance Only] #1504275
09/19/13 12:33 PM
09/19/13 12:33 PM
AUSTRALIA
CLEVO351 Offline OP
CLEVO351  Offline OP
AUSTRALIA
What other info would you like ?
Re: INDY 360-1 SPARK ADVANCE ? [Re: CLEVO351] #1504276
09/19/13 12:36 PM
09/19/13 12:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
on my stock stroke motor it likes 38-40* at the track
Re: INDY 360-1 SPARK ADVANCE ? [Re: Performance Only] #1504277
09/19/13 12:51 PM
09/19/13 12:51 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
same as I run
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: INDY 360-1 SPARK ADVANCE ? [Re: Ian] #1504278
09/19/13 01:01 PM
09/19/13 01:01 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mine loved timing 42* here
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: INDY 360-1 SPARK ADVANCE ? [Re: 1967dartgt] #1504279
09/19/13 01:09 PM
09/19/13 01:09 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have a 408 11.3 comp with dish pistons and have run it at 35-36*. If i'm reading the plug right it could use alittle more timing.
Re: INDY 360-1 SPARK ADVANCE ? [Re: 1967dartgt] #1504280
09/19/13 02:17 PM
09/19/13 02:17 PM
P
P
It really makes me wonder why some of you guys need so much timing. What is so different about your combo with the same identical head that requires it? My guess is it's a Band-Aid to cover up other issues you may not be aware of.
Now, before you chastising me, I've put many Indy heads on small block combo's and I've never had to run more than 35 degrees to make the best power.
as far as reading your plug for timing, perhaps you're just running the wrong plug.
Okay, flame away now.
Re: INDY 360-1 SPARK ADVANCE ? [Re: Performance Only] #1504281
09/19/13 02:22 PM
09/19/13 02:22 PM
K
KOS Offline
KOS  Offline
K
mine likes 40.......Ryan J made another 75hp on the dyno going from 32-33 to 40ish.i pickup 3 tenths at the track from mid 30s to 40!!!! He told me was the combustion chamber design that liked lots of timming.
Re: INDY 360-1 SPARK ADVANCE ? [Re: Performance Only] #1504282
09/19/13 02:31 PM
09/19/13 02:31 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Are the engines pump gas?
Re: INDY 360-1 SPARK ADVANCE ? [Re: W5DART66] #1504283
09/19/13 02:40 PM
09/19/13 02:40 PM
K
KOS Offline
KOS  Offline
K
13.1compression
Re: INDY 360-1 SPARK ADVANCE ? [Re: Performance Only] #1504284
09/19/13 02:53 PM
09/19/13 02:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
maybe I do have the wrong plug, but this plug(ngk 5671a-7) has stayed the cleanest and looked the best out of the other dozen plugs i'v tried. does a flat top piston generally require different timing than a dish piston? I have a friend that has a 440 small block with chapman w7 heads and has found that 38* works best for him with 11.8 comp.
Re: INDY 360-1 SPARK ADVANCE ? [Re: CLEVO351] #1504285
09/19/13 08:02 PM
09/19/13 08:02 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
the 2 sets of 360-1 I had on the dyno made the most at 35 with a flat top piston
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: INDY 360-1 SPARK ADVANCE ? [Re: WHITEDART] #1504286
09/19/13 08:09 PM
09/19/13 08:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how many dyno's have been down the track?
Re: INDY 360-1 SPARK ADVANCE ? [Re: mopar dave] #1504287
09/19/13 08:52 PM
09/19/13 08:52 PM
AUSTRALIA
CLEVO351 Offline OP
CLEVO351  Offline OP
AUSTRALIA
I have built SBF, BBF,SBC most of these engines made best power from 26deg to 30deg of timing,the small blocks made 800hp & the Big block Fords 1050 Hp all tuned on an SF901
engine dyno. Looking at the Indy chamber, im suprised at the amount of timing some of you are running.
Re: INDY 360-1 SPARK ADVANCE ? [Re: Quicktree] #1504288
09/19/13 08:52 PM
09/19/13 08:52 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Jet for best MPH then start adding 1* see how it responds.
Don't get hung up on a number as that's all it is.
My deal was way rich for engine masters that's just how you have to run that deal.
But still it still wanted 38-40* on pump gas in a car and this was 10.75to1 flat top.
Guy on moparts has the engine in a D-50 truck and it runs well.
Re: INDY 360-1 SPARK ADVANCE ? [Re: W5DART66] #1504289
09/19/13 09:35 PM
09/19/13 09:35 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Little different animal, but I put W5 heads on a 11.8 flat top shortblock and they ran best at 40. Turn it back to 36 and it would kill exactly a tenth in back to back passes.
Throw same heads on a 13.3 dome shortblock and ran best at 32
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: INDY 360-1 SPARK ADVANCE ? [Re: W5DART66] #1504290
09/19/13 09:40 PM
09/19/13 09:40 PM
K
KOS Offline
KOS  Offline
K
we built my combo to run 9.7s first few times i had it to the track with the timming at 35-36 after tunning the carb and suspension the best it would run was in the 9.9s.i spoke with Ryan first thing he asked is where i had the timming when i told him he said go back kick it up to 40-42 so i did and the car instantly went from 9.9s into the 9.7s with a best of a 9.64.then he told me the story about a dyno session where they where dissapointed of the power a certain indy headed combo made until he tried playing with the timming and picked up 75hp with a 5degree increase which i kinda believe after how much i picked up at the track.
Re: INDY 360-1 SPARK ADVANCE ? [Re: KOS] #1504291
09/19/13 09:53 PM
09/19/13 09:53 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
My 408 loved a lot of timing, best was at 37*, but from what I see here, I sould have tried to 38-40 on the dyno....
Page 1 of 3 1 2 3
