Re: INDY 360-1 SPARK ADVANCE ?
[Re: CLEVO351]
#1504273
09/19/13 12:28 PM
09/19/13 12:28 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Timing will depend on other factors you haven't mentioned, but typically we find they like about 33 degree's total. I use NGK non-projected tips in a heat range compatible with the application. I'd start out with a -7 plug on a street car.
machine shop owner and engine builder
[Re: Performance Only]
#1504275
09/19/13 12:33 PM
09/19/13 12:33 PM
Posts: 28 AUSTRALIA
CLEVO351
AUSTRALIA
What other info would you like ?
#1504277
09/19/13 12:51 PM
09/19/13 12:51 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
same as I run
[Re: Ian]
#1504278
09/19/13 01:01 PM
09/19/13 01:01 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Mine loved timing 42* here
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1504280
09/19/13 02:17 PM
09/19/13 02:17 PM
Performance Only
It really makes me wonder why some of you guys need so much timing. What is so different about your combo with the same identical head that requires it? My guess is it's a Band-Aid to cover up other issues you may not be aware of. Now, before you chastising me, I've put many Indy heads on small block combo's and I've never had to run more than 35 degrees to make the best power. as far as reading your plug for timing, perhaps you're just running the wrong plug.
Okay, flame away now.
#1504282
09/19/13 02:31 PM
09/19/13 02:31 PM
Posts: 1,784 PA
W5DART66
PA
Are the engines pump gas?
[Re: W5DART66]
#1504283
09/19/13 02:40 PM
09/19/13 02:40 PM
KOS
[Re: W5DART66]
#1504289
09/19/13 09:35 PM
09/19/13 09:35 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Little different animal, but I put W5 heads on a 11.8 flat top shortblock and they ran best at 40. Turn it back to 36 and it would kill exactly a tenth in back to back passes. Throw same heads on a 13.3 dome shortblock and ran best at 32
