Hooker vs Mad Dog vs TTI #1503763
09/18/13 11:51 AM
09/18/13 11:51 AM
Rochester, PA (near Pittsburgh...
1974 474 Duster Online content OP
1974 474 Duster  Online Content OP
Looking to see if anyone has some good input here. My car currently has Hooker 2' fenderwell headers on it. Would love to do away w/them, but don;t want to lose power & such. Has anyone here switched to Mad Dog's or TTI's?? If so what was the gain / loss on your part. Please let me know or give me ideas here. Another broken header tube put me out of action at MMW. Want to try & get away from these issues.
Thank you, Ken Michalik
Re: Hooker vs Mad Dog vs TTI [Re: 1974 474 Duster] #1503764
09/18/13 12:00 PM
09/18/13 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No off the shelf header is built to match YOUR engine..
most are built to fit the engine/body combo... most
headers the primary length is too long and the collector
is too small in both diameter and length... its been
about 20 years or more since I bought a shelf header
and those were Hooker super comp and were decent but
not perfect for my combo so I added length to the
collector to help them
Re: Hooker vs Mad Dog vs TTI [Re: MR_P_BODY] #1503765
09/18/13 12:03 PM
09/18/13 12:03 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Ken,just let us build a custom set for you.
Re: Hooker vs Mad Dog vs TTI [Re: B G Racing] #1503766
09/18/13 01:45 PM
09/18/13 01:45 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Hooker vs Mad Dog vs TTI [Re: Butch] #1503767
09/18/13 01:48 PM
09/18/13 01:48 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Why not Hedman Hustlers?
Re: Hooker vs Mad Dog vs TTI [Re: B1MAXX] #1503768
09/18/13 02:07 PM
09/18/13 02:07 PM
Trying to get away from the fenderwell exit. The Hedman is a far superior header to the Hooker. I know that for sure. Just trying to get away from that style exit.
Thanks, Ken
Re: Hooker vs Mad Dog vs TTI [Re: 1974 474 Duster] #1503769
09/18/13 02:27 PM
09/18/13 02:27 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Mad Dog
Joey
Re: Hooker vs Mad Dog vs TTI [Re: 1974 474 Duster] #1503770
09/18/13 03:29 PM
09/18/13 03:29 PM
Which year body and style and the same on the motor and heads I have ran the Hookers, Hedmans and the early two inch Pro Parts in both the early Darts(1967 and later) and Cuda as well as Dusters with both B and RB motors, the Pro Parts won't work well in a A body with a B motor and stock type heads, they hit the starter and oil pan plus I had to squeeze one or two tubes down some Also which type motor mounts are you using On my Duster with the Hooker two inch primarys it didn't matter which motor or heads I had on them, no problems on either type motor On the Hedmans made for the Indy heads I had to raise up the low deck stroker motor with the Indy SR heads up to clear the inner fenderwells Not so on the RB motors, I used elephant ears also so raising and lowering the motor was not a big deal in that car I also bought a set of two inch Mad Dogs for a low deck and never used them, I put the stock A body exhaust manifolds back on my 383 H code 1969 dart GTS
Re: Hooker vs Mad Dog vs TTI [Re: Cab_Burge] #1503771
09/18/13 03:39 PM
09/18/13 03:39 PM
Cab,
I have a 74 Duster w/B 400 block. But it has the Mopar Stage 6 head which raises the port a bit. I use stock spool type mounts on it as well.Like I said just want to do away w/fenderwell headers on it.
Thanks, Ken
