Dakota 5.2 injector upgrade question.. #1503183
09/17/13 04:05 PM
09/17/13 04:05 PM
Tampa, Fl
valiantboy Offline OP
super gas
super gas
Tampa, Fl
i have a 93 dakota with a 5.2 and im looking to upgrafe to a more efficient injector. i have heard that the injectors from a ford 4.6 or 5.4 will work. has anyone done this before?
Re: Dakota 5.2 injector upgrade question.. [Re: valiantboy] #1503184
09/17/13 06:18 PM
09/17/13 06:18 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
ford 5.0 injectors they have 5 spray holes. if stock stay 19lbs
Re: Dakota 5.2 injector upgrade question.. [Re: d-150] #1503185
09/18/13 12:33 AM
09/18/13 12:33 AM
Clinton Twp. Michigan
coronet1966d Offline
I have some ford 24lb blue 4 hole injectors for that swap
Re: Dakota 5.2 injector upgrade question.. [Re: d-150] #1503186
09/18/13 06:53 PM
09/18/13 06:53 PM
Harper's Ferry WV
aardakota Offline
aardakota  Offline
Harper's Ferry WV
What year 5.0 injector are you referring to? I am assuming the electrical connection is the same. thanks
Re: Dakota 5.2 injector upgrade question.. [Re: valiantboy] #1503187
09/19/13 07:51 AM
09/19/13 07:51 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
these Holley fuel injectors have been cited by professional engine researchers as having fine atomization
http://www.ebay.com/itm/Holley-522-248-U...ee3&vxp=mtr
i dont know how resistant they are to clogging over the long term
going up to 30 lbs per hour injectors has no advantage on gasoline, but would probably allow operation on e85 fuel, which would give a horsepower gain
are you going to run at factory stock 35 to 39 psi fuel pressure
or 43.5 psi ?
Re: Dakota 5.2 injector upgrade question.. [Re: 360view] #1503188
09/22/13 12:15 PM
09/22/13 12:15 PM
Tampa, Fl
super gas
super gas
Tampa, Fl
for right now, im going to leave the fuel pressure alone. i want to see what difference the injectors make. i plan on doing a plug swap when i change the injectors so i can get a true read on what it needs. its running a tad rich at the moment.
I'm WAY too baked to drive to the devil's house.
