Did I mess up? #1502899
09/16/13 11:05 PM
09/16/13 11:05 PM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
I just clocked 1000 miles on the hemi in my 68 GTX. It's an all new engine built from one of the cummins made blocks with stage v heads. 'Been noticing it running a little warmer. It's never boiled or puked out the overflow but running to the right of normal. I had the original 26 in radiator recored with a 3 row high efficiency core, 160 thermostat (I didn't know about high flow t stats at the time.) and I used gold coolant. I work in a new car dealership and have always thought the gold beat the old green hands down. A recent article in mopar action agreed. Anyway looking through the fill neck about every flue I can see is clogged. Scratching with a pick confirmed it is rust. Was the gold coolant a mistake, or maybe because its a new virgin block? What's a good chemical that will clean it without making a mess? It's detailed nicely and I hate to ruin the paint on the engine or anywhere else. Is there something I can run and drain the block and radiator afterward that will dissolve it? Also if I can get it clean what coolant would you run and is there a good additive to keep it clean?
Re: Did I mess up? [Re: Silverbullet2] #1502900
09/16/13 11:24 PM
09/16/13 11:24 PM
I'm assuming the gold stuff is the GO5? good stuff. iirc the dexcool is the bad stuff. But I thought it was a coagulating/compatibility with other types issue not a rust issue. I would flush the block & have the rad recleaned then that'll give you time to decide on the best antifreeze (I like the good ole green) AND to investigate where the particles came from (rust or otherwise) & a course of action
Re: Did I mess up? [Re: RapidRobert] #1502901
09/16/13 11:30 PM
09/16/13 11:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Want it SUPER rust free? Buy 2 gallons of Evaporust (Harbor Freight). Get your engine warm, dump your coolant, refill with Evaporust, run until it warms up and you are 100% certain the thermostat is open. After the Evaporust has made the rounds shut off the engine and let it sit overnight. Next day, fire it up until it's warm again and TS is open. Drain the Evaporust (save it, it's reusable) and refill with your choice or coolant. Your radiator, block, and any other metal it contacts and soaks will be free of rust, stuff works amazingly well and absolutely will not harm your engine or radiator, etc.
Re: Did I mess up? [Re: ScottSmith_Harms] #1502902
09/17/13 03:02 AM
09/17/13 03:02 AM
California
mickm Offline
mickm  Offline
California
and while you are working on that, how bout some pictures of the car??
Re: Did I mess up? [Re: mickm] #1502903
09/17/13 11:06 AM
09/17/13 11:06 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
YEH!without pics it dont exist.
Re: Did I mess up? [Re: bonefish] #1502904
09/17/13 07:22 PM
09/17/13 07:22 PM
North Carolina, USA
North Carolina, USA
Re: Did I mess up? [Re: Silverbullet2] #1502905
09/17/13 07:24 PM
09/17/13 07:24 PM
North Carolina, USA
North Carolina, USA
Hope you guys can get this pic. I'm not great with moving pics around. And Scott the Evaporust sounds like the ticket. Thanks buddy!
Re: Did I mess up? [Re: Silverbullet2] #1502906
09/17/13 07:27 PM
09/17/13 07:27 PM
North Carolina, USA
North Carolina, USA
Re: Did I mess up? [Re: Silverbullet2] #1502907
09/17/13 08:06 PM
09/17/13 08:06 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
One more... https://scontent-b.xx.fbcdn.net/hphotos-ash4/397110_3052124027899_1968616828_n.jpg
i can only think of one word to describe your car,FREAKINAWSOME!!!
Re: Did I mess up? [Re: bonefish] #1502908
09/17/13 08:16 PM
09/17/13 08:16 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
That is a beautiful car. I am sooooo jealous!
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Did I mess up? [Re: FJR doc] #1502909
09/17/13 10:14 PM
09/17/13 10:14 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Are those 3" tti's?
Re: Did I mess up? [Re: ScottSmith_Harms] #1502910
09/17/13 10:40 PM
09/17/13 10:40 PM
BDW Offline
BDW  Offline
Is this suggested for a "normal" radiator flush? Or only for this special circumstance?
Re: Did I mess up? [Re: BDW] #1502911
09/17/13 11:58 PM
09/17/13 11:58 PM
North Carolina, USA
North Carolina, USA
Well thanks a million guys for the kind words! Lot of blood, sweat and money getting it there, and yes it's a complete TTI 3 in exhaust. I plan to get original looking oval tips on it at some point. It's a 4 speed and the Dana is carrying 4.10s at present so it's purty snappy from stoplight to stoplight!
Re: Did I mess up? [Re: Silverbullet2] #1502912
09/18/13 09:41 AM
09/18/13 09:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
another thing after you get it flushed use distilled water for the fill. I only use that and water wetter, but I race mine and anti-freeze is NOT a good thing to loose at WOT. I run a 2 core aluminum rad and stage VI heads, car never gets above 190* even in traffic.
Coming soon!!!!
Re: Did I mess up? [Re: Mr.Yuck] #1502913
09/24/13 07:08 AM
09/24/13 07:08 AM
North Carolina, USA
North Carolina, USA
Did the evaporust procedure sunday and yesterday. It definitely cleaned the cooling system and it's running cooler too, but of course the weather has been cooler also. Went back with green coolant and a pint of rust and scale inhibitor. Although Scott didn't specify it I refilled and drained the block and radiator with plain water first to rinse out all the evaporust. I'm almost certain my gauge is reading high. It went almost to the top of the normal range before the thermostat opened and it backed down to a hair past middle ways. I'm running a rally instrument cluster and the top of normal is about 230 degrees. Since I was able to stick my finger in the fill neck without scalding it at the time I doubt if it was anywhere near 230. I may try another temp sender and see if it changes.
Re: Did I mess up? [Re: Silverbullet2] #1502914
09/24/13 07:17 AM
09/24/13 07:17 AM
North Carolina, USA
North Carolina, USA
Here's a shot of the interior. Since then I've replaced the steering wheel and added the bright pedal dress up.
Re: Did I mess up? [Re: Silverbullet2] #1502915
09/24/13 09:01 AM
09/24/13 09:01 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
Car is awesome.
Try throwing a high temp thermometer in the rad to get a real number.
Re: Did I mess up? [Re: Silverbullet2] #1502916
09/24/13 01:53 PM
09/24/13 01:53 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Once the car is fully warmed up & thermostat opened, you can pop the cap with the engine running. Then simply stick a $5.00 meat thermometer in there & see what it's running at. Now you know what temp = what line on the factory gauge.
Re: Did I mess up? [Re: 80fbody] #1502917
09/24/13 02:10 PM
09/24/13 02:10 PM
dogdays Offline
dogdays  Offline
Check your timing to see if it is retarded. After you make sure it isn't, stop worrying and DRIVE THE CAR!
How hot is too hot? If it pukes green blood out of the radiator with a new cap, that's too hot.
Running a little to the right of center on the gauge? So what? The gauge is not a precision instrument...just drive the doggone car. You may find that it even runs cooler after a few thousand miles.
Enough with the worry!
R.
Re: Did I mess up? [Re: dogdays] #1502918
09/24/13 02:45 PM
09/24/13 02:45 PM
California
mickm Offline
mickm  Offline
California
i noticed you have hose around the fuel line to from the vapor separator to the tee. is it in contact with the heater hoses? were you having issues heating the line?
