Re: Did I mess up?
[Re: Silverbullet2]
#1502900
09/16/13 11:24 PM
09/16/13 11:24 PM
RapidRobert
I'm assuming the gold stuff is the GO5? good stuff. iirc the dexcool is the bad stuff. But I thought it was a coagulating/compatibility with other types issue not a rust issue. I would flush the block & have the rad recleaned then that'll give you time to decide on the best antifreeze (I like the good ole green) AND to investigate where the particles came from (rust or otherwise) & a course of action
Re: Did I mess up?
[Re: RapidRobert]
#1502901
09/16/13 11:30 PM
09/16/13 11:30 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Want it SUPER rust free? Buy 2 gallons of Evaporust (Harbor Freight). Get your engine warm, dump your coolant, refill with Evaporust, run until it warms up and you are 100% certain the thermostat is open. After the Evaporust has made the rounds shut off the engine and let it sit overnight. Next day, fire it up until it's warm again and TS is open. Drain the Evaporust (save it, it's reusable) and refill with your choice or coolant. Your radiator, block, and any other metal it contacts and soaks will be free of rust, stuff works amazingly well and absolutely will not harm your engine or radiator, etc.
Re: Did I mess up?
[Re: mickm]
#1502903
09/17/13 11:06 AM
09/17/13 11:06 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
and while you are working on that, how bout some pictures of the car??
YEH!without pics it dont exist.
Re: Did I mess up?
[Re: ScottSmith_Harms]
#1502910
09/17/13 10:40 PM
09/17/13 10:40 PM
Posts: 4,723 Florida
BDW
Is this suggested for a "normal" radiator flush? Or only for this special circumstance?
