Thoughts on Q16 #1501701
09/15/13 12:27 PM
09/15/13 12:27 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Hey guys, that time of year where all I can think about is squeezing every little ounce of performance out of my 71 Duster. I have been thinking about trying some q16 fuel. From what I have read, the more air starved your combination is, the bigger return you will get from it. My motor is probably about as air starved combo you can come up with. I am looking for tips, tricks, etc. to get the most out of the switch. Currently I am running c16 which is probably overkill for the motor (all cast iron, 13.5 comp), but the cranking compression is around 250psi so I just want to be safe. I realize I have to jet up, but read conflicting information on how much to start with. What is the target a/f? Same as normal gas?
What about timing? Does it HAVE to be dropped? My motor likes pretty low timing but getting it so low kills bottom end tq (may put on a programmable box).
Sorry for the long post.
Thanks guys
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Thoughts on Q16 [Re: F1Scamp] #1501702
09/15/13 12:55 PM
09/15/13 12:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
if q16 is oxygenated fuel,vp old me 4 jet sizes up with their 100 streetblaze. no change in timing needed.
Re: Thoughts on Q16 [Re: mopar dave] #1501703
09/15/13 02:12 PM
09/15/13 02:12 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
C16 is a "heavy" fuel, more suited to boosted combinations. I use it in a 1700hp blown street car. No way is it the correct fuel for your combination.
If you wanna try oxy fuel.....with your CR, VP113 may be a better choice, possibly C12, or C14 in non-oxy.
Re: Thoughts on Q16 [Re: F1Scamp] #1501704
09/15/13 04:02 PM
09/15/13 04:02 PM
AndyF Offline
AndyF  Offline
You can try it, but I'm not sure if you have enough compression to make it work. VP recommends a minimum of 14:1 compression for Q16.
I've tried it in lower compression engines without much luck. In my 514 it worked pretty well, but that engine has 15.5 compression.
Re: Thoughts on Q16 [Re: AndyF] #1501705
09/15/13 07:41 PM
09/15/13 07:41 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
I didn't realize they made a oxygenated 113 octane fuel. It says it is good for up to 14:1 and oxygenated to street gas levels. I guess I won't know which one works best till I try them. Too bad you have to buy it in 5gal cans. Wonder if you could mix them?
Re: Thoughts on Q16 [Re: F1Scamp] #1501706
09/15/13 07:44 PM
09/15/13 07:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
why are you running stock exhaust? are you running FAST or something.
Re: Thoughts on Q16 [Re: Quicktree] #1501707
09/15/13 07:52 PM
09/15/13 07:52 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Yes, current smallblock record holder in FAST. Car ran 11.27 @ 120.5, now it has about 40hp more and 43lbs lighter. Trying to break the 10second barrier in FAST form.
Re: Thoughts on Q16 [Re: Quicktree] #1501708
09/15/13 07:55 PM
09/15/13 07:55 PM
K
KOS Offline
KOS  Offline
K
i tried q16 against c12 in my 13.1 small block stroker it was worth a tenth but you might have to get into changing the air bleeds i couldnt put enough jet in my QF 1050dom.i believe it has 10%oxygen the 113 is 6%or8% so might be better suited in your application.i wanted to try the 113 but was hard to get ahold of around here.
Re: Thoughts on Q16 [Re: KOS] #1501709
09/15/13 09:17 PM
09/15/13 09:17 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Well that's encouraging. It would awesome if it would give me a tenth. Of course, the more hp I give it, the harder and harder it is to get it off the line.
Re: Thoughts on Q16 [Re: F1Scamp] #1501710
09/16/13 11:10 AM
09/16/13 11:10 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Q16 works very well. You need 5 jet sizes and air bleed work. It also burns very clean.
Re: Thoughts on Q16 [Re: F1Scamp] #1501711
09/16/13 12:45 PM
09/16/13 12:45 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Brian...
It works...Aside from being a VP fuel dealer, I have many dyno tests to prove the fuel does whats its supposed to..I have been using it since it first came out and worked with a VP engineer on getting up to speed on running this fuel safely and effectively. I have also recommended and worked through several other combos for friends and fuel customers that have run their best times on the Q16. These guys swear by it now..
There is special handling invoived..Jetting is important as is timing. Also some other more mundane stuff.
It is an IDEAL fuel for FAST type engines..Many of the records set might not even have been possible without the oxygenated fuel.
Call me if you want...I have a lot of experience and R & D with this fuel. It will work for you.
MB
Re: Thoughts on Q16 [Re: HPMike] #1501712
09/16/13 01:41 PM
09/16/13 01:41 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
Brian...
MB
Mike do you think I should go with Q16 or do you think the VP113 would be better suited? The motor is 13.5:1 with 250psi of cranking compression.
Re: Thoughts on Q16 [Re: F1Scamp] #1501713
09/16/13 01:53 PM
09/16/13 01:53 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Brian...
MB
Q16
No doubt...If you can get it on a chassis dyno, great..I am thinking I will be at MIR..If you want ill help you out...
MB
Re: Thoughts on Q16 [Re: HPMike] #1501714
09/16/13 02:03 PM
09/16/13 02:03 PM
NY
F1Scamp Offline OP
F1Scamp  Offline OP
NY
I am going to try it at the Mopar day at leabonan valley in 2 weeks. If the car picks up, I will def. be using at MIR.
Re: Thoughts on Q16 [Re: F1Scamp] #1501715
09/16/13 02:13 PM
09/16/13 02:13 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Gimme a call if you need any tuning assistance...The O2 reading #s cant really be relied on, like you would for conventional fuels.
MB
Re: Thoughts on Q16 [Re: F1Scamp] #1501716
09/16/13 02:55 PM
09/16/13 02:55 PM
Trumbull,CT.
Trumbull,CT.
That is so cool I can't stand it!!!
If the Q16 can give you a tenth+, that would be sweet. Good luck with the hunt for 10s.
Re: Thoughts on Q16 [Re: jim sciortino] #1501717
09/16/13 03:14 PM
09/16/13 03:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have been using it for a LONG time and have helped a number of folks make the transition. There is NO Magic jet number for making the switch. VP will tell you 5% more is a good starting point. We have found some combinations have taken up to 10% more. IN my car it was about 8% more jet and a lot of bleed work. As for A/F ratio we have seem to make the best power at 12.6 or so in my B1 and the Pro Stock 99 Hemi I have. That has also been close on every car we have worked on. It will take quite a bit more fuel to get it there over a conventional fuel. Another option might be C25, it is expensive but it makes power too...
Re: Thoughts on Q16 [Re: F1Scamp] #1501718
09/16/13 04:25 PM
09/16/13 04:25 PM
AndyF Offline
AndyF  Offline
There might not be too many folks still alive who know how to change the fuel curve on a Thermoquad! You don't have the luxury of adjustable air bleeds and unlimited jet sizes like a Holley.
Be sure to drain the carb after every race. That Q16 might turn the TQ into jelly if you leave it in there too long.
Re: Thoughts on Q16 [Re: AndyF] #1501719
09/16/13 05:21 PM
09/16/13 05:21 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Brian
I think I will try that out with you. HP Mike did make more power on the dyno (I think 16HP)with the Q but I never saw results at the track.
And draining it out of the car is a must. Eat up my accellerator pump in about 4 hrs.
One thing that did happen when using it is at about the 1000' the engine would feel like it was running out of fuel for a split second and then come back to life? This happened every time with the Q never with c16 I don't know if anyone else has had this issue.
Maybe HP Mike can make a track visit we have not seen him in a while?
Ed Cook
Re: Thoughts on Q16 [Re: XXHEMI] #1501720
09/16/13 08:57 PM
09/16/13 08:57 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I've been using it for a number of years also. Most of the comments about what needs to be changed in the tune up is correct. As far as the running out of fuel situation, I had the same thing happen and the cure was changing to a bigger needle & seat to allow more fuel into the bowl.
