Diablo Season Update. 4x4 Truck pulling/Hemi***Video***
#1500839
09/13/13 04:38 PM
09/13/13 04:38 PM
Posts: 1,107 Quebec, Canada
Diablo
Quebec, Canada
Well another season has come and gone and I'm happy to say this one has been a very good one for us! We started the season a bit hesitant and nervous after having engine problems last year and were taking our time taking off during the runs. The start of the season we were placing 3rd most of the time out of 8-11 trucks. Which is still solid but not exactly where we wanted to be. When we got our confidence up some more with the truck we were coming into it much quicker and the second half of the season was full of Second places and we ended the season with a win! We had no mechanical failures with the truck all season which helped with the consistent season. The problem we have is beating some of the high HP clutch trucks on the power tracks. We run a Converter trans and when the weight comes on during the run the converter can't keep a constant efficiency and we are losing tire speed which means footage at the end of the track. We ended the season 3rd overall in points but if we ran the truck hard at the start of the year i'm sure 2nd overall was ours. For next year we will be trying some new ideas on transmission set ups. Either we will just have to go with a clutch set up or maybe try a Lock up Style converter and try and get the best of both worlds from it. Here are the two runs of the last pull of the season where we won. In both these runs the engine ran to about 8700RPM. And for those who Don't know its a 650ci 5inch Bore space Goodwin Hemi:) Enjoy!! Full pull Run http://www.youtube.com/watch?v=u4GwYlnBCQ8&feature=youtu.bePull off Run to win! http://www.youtube.com/watch?v=XKXx4uyr2vc&feature=youtu.be
Re: Diablo Season Update. 4x4 Truck pulling/Hemi***Video***
[Re: Diablo]
#1500844
09/13/13 08:22 PM
09/13/13 08:22 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I agree sounds great, How many RPM you spin it to?
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: mac56]
#1500848
09/14/13 03:48 PM
09/14/13 03:48 PM
Posts: 20,652 in a cattle trailer down by th...
Guitar Jones
Jeebus that sounds sweet. Just what do you have in there for a trans?
[Re: Guitar Jones]
#1500852
09/16/13 09:08 AM
09/16/13 09:08 AM
Posts: 976 ontario canada
mac56
ontario canada
I believe Doug is still running a 727 in front of his quick change transfer.
