.040 intake p/v too tight?
#1500639
09/12/13 09:59 PM
09/12/13 09:59 PM
Posts: 312 illinois
dodgeram1998
illinois
#1 Piston, all valve train mocked up, lash 0.0 , dial indicator mounted on intake rocker, roll over to TDC on the intake stroke, push down on rocker .078 movement, 5 degrees after TDC .041 clearance, 10 degrees after TDC .039 clearance, Exhaust valve P/V clearance minimum at 10 BTDC IS .108 I don't remember if I put this 278@.050 roller cam in straight up or advanced but it looks like retarding it would not be a option with the .108 clearance. 440ci .060 over steel rod .040 HEAD gasket looking for fixes LOL (piston valve notches). or run it BB- BOOOOMM?? anyone run .040 P/V intake clearance? I think the exhaust will suffice Thanks
Re: .040 intake p/v too tight?
[Re: dodgeram1998]
#1500647
09/13/13 08:15 AM
09/13/13 08:15 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I think with the lash set you'll be ok, you could retard the cam 2* and see what you get. I have run as little as .080 on the exhaust and .068 on the intake without a problem in my small block.
[Re: LSP]
#1500648
09/13/13 08:24 AM
09/13/13 08:24 AM
Posts: 1,784 PA
W5DART66
PA
You'll have a good bit more P to V than that (likely .020"-.030") with actual springs on it.
^^^^^^^ this
Check with real springs.
What heads, rocker set up?
If its mopar single shaft deal it will be like .050" more plus your lash.
[Re: W5DART66]
#1500649
09/13/13 08:35 AM
09/13/13 08:35 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You should see another .010 from adding the springs you will run and adding the lash in should get you to about .07+? I have run .050, but the pistons didn't let carbon build up where the valves brushed them, and that was a 6200 rpm stroker. So, I would look for at least .075 to err on the safe side. The really tough one is the exhaust. Don't go below the suggested minimum there, as the valve is closing when the piston is close and if there is any valve train issues you will have contact a lot earlier.
[Re: B1MAXX]
#1500655
09/13/13 05:53 PM
09/13/13 05:53 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Like the rest, the first thing you should do is degree the cam then check P to V. If it is close with '0' lash, under .080" with the gasket, the pistons need a deeper notch. Do it right the first time or you will have to do it right later anyways with more expence of broken parts.
[Re: dvw]
#1500658
09/14/13 10:48 PM
09/14/13 10:48 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I wouldn't be afraid of .040" with checking spring and zero lash. You are going to gain from deflection,spring pressure and lash. If you're worried install one of your springs and lash it. That removes all guessing. Doug
