.040 intake p/v too tight? #1500639
09/12/13 09:59 PM
09/12/13 09:59 PM
illinois
dodgeram1998 Offline OP
illinois
#1 Piston, all valve train mocked up, lash 0.0 , dial indicator mounted on intake rocker, roll over to TDC on the intake stroke, push down on rocker .078 movement, 5 degrees after TDC .041 clearance, 10 degrees after TDC .039 clearance,
Exhaust valve P/V clearance minimum at 10 BTDC IS .108
I don't remember if I put this 278@.050 roller cam in straight up or advanced but it looks like retarding it would not be a option with the .108 clearance.
440ci .060 over steel rod .040 HEAD gasket
looking for fixes LOL (piston valve notches). or run it BB- BOOOOMM??
anyone run .040 P/V intake clearance?
I think the exhaust will suffice
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500640
09/12/13 10:27 PM
09/12/13 10:27 PM
illinois
illinois
I think moparts will say .040 is to tight of a clearance , the .040 headgasket is my my quench so the easiest resolution for me prolly is gonna be a less duration cam
Other ideas appreciated
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500641
09/12/13 11:47 PM
09/12/13 11:47 PM
If you have not set(degreed) the lobe centers yet check it and see where the intake lobes are now and go from there BTW, is this with a set of checking springs or the ones you will run? If checking springs and with a solid lifter cam set the lash and recheck it again
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500642
09/12/13 11:52 PM
09/12/13 11:52 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
You'll have a good bit more P to V than that (likely .020"-.030") with actual springs on it.
Re: .040 intake p/v too tight? [Re: Cab_Burge] #1500643
09/13/13 01:21 AM
09/13/13 01:21 AM
illinois
illinois
I hope you are right about the checking spring because yes they were checking spring and I considered that the spring didn't pull up hard on the valve as I manipulated the valve with my hand as hard as I could pull up on the retainer and zeroing the dial indicator,
290 LBS SPRING on the seat I will have to get out something stronger to manipulate the valve eh. any ideas as to what tool will manipulate? on the car valve spring remover?
it will be fun trying to PV clearancing the rest of the cylinders also if I come up with good clearance on cylinder#1
I will check it out and report back
thanks
Re: .040 intake p/v too tight? [Re: LSP] #1500644
09/13/13 01:23 AM
09/13/13 01:23 AM
illinois
illinois
I Hope you are right about them checking springs if I had .070 clearance I would be feeling it would be worth while to go on further and do the rest of the cylinders
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500645
09/13/13 01:29 AM
09/13/13 01:29 AM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
I agree. Install the real springs, set the lash and recheck.
Re: .040 intake p/v too tight? [Re: SuperStocker] #1500646
09/13/13 01:36 AM
09/13/13 01:36 AM
illinois
illinois
Considering lash I had the lash set at zero? Doesn't the lash zero out hot ? if not then this would have been an error my part?
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500647
09/13/13 08:15 AM
09/13/13 08:15 AM
Guitar Jones Offline
I think with the lash set you'll be ok, you could retard the cam 2* and see what you get. I have run as little as .080 on the exhaust and .068 on the intake without a problem in my small block.
Re: .040 intake p/v too tight? [Re: LSP] #1500648
09/13/13 08:24 AM
09/13/13 08:24 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
^^^^^^^ this
Check with real springs.
What heads, rocker set up?
If its mopar single shaft deal it will be like .050" more plus your lash.
Re: .040 intake p/v too tight? [Re: W5DART66] #1500649
09/13/13 08:35 AM
09/13/13 08:35 AM
gregsdart Offline
gregsdart  Offline
You should see another .010 from adding the springs you will run and adding the lash in should get you to about .07+? I have run .050, but the pistons didn't let carbon build up where the valves brushed them, and that was a 6200 rpm stroker. So, I would look for at least .075 to err on the safe side. The really tough one is the exhaust. Don't go below the suggested minimum there, as the valve is closing when the piston is close and if there is any valve train issues you will have contact a lot earlier.
Re: .040 intake p/v too tight? [Re: W5DART66] #1500650
09/13/13 10:39 AM
09/13/13 10:39 AM
illinois
illinois
the heads are indy sr 2.14/1.81 with the Harland sharps 1.6in/1.5 es . My other shot at it is to lose the 1.6 on the intake to see if that will help
I will go out in the shop later today and try again if time allows
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500651
09/13/13 11:03 AM
09/13/13 11:03 AM
Az
Crizila Offline
Crizila  Offline
Az
Yes, going to 1.5's will help. FYI, Hughes rents a tool that will cut the valve notches deeper with the short block assembled if you need to go that route. I did it on a sm blk and it worked good. You could also run a little looser lash than what's called for.
Fastest 300
Re: .040 intake p/v too tight? [Re: Crizila] #1500652
09/13/13 11:42 AM
09/13/13 11:42 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Starting with checking springs and a dial ind. is a good start, but then I like to use clay on all 8 pistons with the correct springs.
This summer, I had 040 on intake with a thinner gasket of 051 because I didnīt want to test with the new cometics that are 060.
This was with lash and checking springs.
Do a check with clay and correct springs.
Exhaust needs more, when the piston is chasing the closing exhaust valve, and not the other way around( intake chasing piston down).
Any flex in cam, cam drive and valve train will benefit the intake clearance.
Re: .040 intake p/v too tight? [Re: RT540] #1500653
09/13/13 12:56 PM
09/13/13 12:56 PM
illinois
illinois
thanks for all the support
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500654
09/13/13 01:22 PM
09/13/13 01:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
0 lash is the main problem. with 0 lash the ramp starts up way sooner.
Re: .040 intake p/v too tight? [Re: B1MAXX] #1500655
09/13/13 05:53 PM
09/13/13 05:53 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Like the rest, the first thing you should do is degree the cam then check P to V.
If it is close with '0' lash, under .080" with the gasket, the pistons need a deeper notch.
Do it right the first time or you will have to do it right later anyways with more expence of broken parts.
Re: .040 intake p/v too tight? [Re: dodgeram1998] #1500656
09/14/13 05:03 AM
09/14/13 05:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If it's still on the engine stand, I would just pull it apart and machine the pistons for more clearance now than be a factor in the future.
When I built my 500" stroker I went with a smaller cam because if P-V clearance issues, when I should have just milled the pistons then. Now that the engine is apart again, I'm going to do what I should have done two years ago.
Re: .040 intake p/v too tight? [Re: 451Mopar] #1500657
09/14/13 06:17 PM
09/14/13 06:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I wouldn't be afraid of .040" with checking spring and zero lash. You are going to gain from deflection,spring pressure and lash. If you're worried install one of your springs and lash it. That removes all guessing.
Doug
Re: .040 intake p/v too tight? [Re: dvw] #1500658
09/14/13 10:48 PM
09/14/13 10:48 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Doug
