wiper blade refill source
#1498180
09/08/13 02:16 PM
09/08/13 02:16 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hello All, Where is a reliable source for wiper blade refills in both 15" and 16"...
Cheers,
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: wiper blade refill source
[Re: hemi68charger]
#1498181
09/09/13 01:01 AM
09/09/13 01:01 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Original wiper assemblies and blades were Anco. Keep your old stainless Anco blade holder and simply install new rubber made by Trico or whoever.
[Re: kentj340]
#1498182
09/09/13 07:14 AM
09/09/13 07:14 AM
hemi68charger
Houston, Tx
Yes,,,, that's the problem. I'm not having any success finding the refills, don't want the blade holder... Looking for a source for the rubber refills......
[Re: hemi68charger]
#1498183
09/09/13 01:10 PM
09/09/13 01:10 PM
hemi68charger
Houston, Tx
I have googled 16" and have gotten some ANCO and Trico hits, but there are a wide selection of possibilities... Anyone recently purchased any refills and have the part number?
Thanks..
[Re: idrivevintage]
#1498186
09/10/13 08:00 AM
09/10/13 08:00 AM
hemi68charger
Houston, Tx
Thanks guys. Friend bought a pair of replacement wipers from YearOne, so I just took the actual wipers out and inserted those into his original blade holders. Thank you for your input.
Cheers
[Re: hemi68charger]
#1498189
09/11/13 02:20 AM
09/11/13 02:20 AM
kentj340
Cut and Shoot, TX
To be more specific, what I meant was to remove the rubber from the stainless flat piece (arrow), and install new rubber. This is a bit tedious, but what is available at car parts stores now is often mounted in plastic or other. All you need to worry with is the right profile of the rubber...
[Re: 52savoy]
#1498190
09/11/13 01:25 PM
09/11/13 01:25 PM
hemi68charger
Houston, Tx
If your looking for nos, I have some 15" Trico refills.
Thanks for the offer..... I appreciate it..... But, we found what we were looking for......
The blades Hoss bought at the same metal frame/retainer as that pictured in your reply, so I just swapped out his old ones for the new ones, perfect.....
[Re: hemi68charger]
#1498191
09/12/13 06:32 PM
09/12/13 06:32 PM
Posts: 406 California City, CA
dart440
California City, CA
If you are looking for refills (not complete blades) at stores like Autozone and O'Reilly, you won't find them on the shelves. You have to ask the counter person for the "refills", as they hide them in the back (so they can sell you replacement blades for 6X the cost).
Sucks as the blades don't fit under most hoods on models with hideaway wipers.
You can take them apart as you like and swap the parts around.
When you work on Spaceships for a living, how bad can a workday be?
