wiper blade refill source #1498180
09/08/13 02:16 PM
09/08/13 02:16 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hello All,
Where is a reliable source for wiper blade refills in both 15" and 16"...
Cheers,
Troy
Houston Mopar Connection Club
Re: wiper blade refill source [Re: hemi68charger] #1498181
09/09/13 01:01 AM
09/09/13 01:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Original wiper assemblies and blades were Anco. Keep your old stainless Anco blade holder and simply install new rubber made by Trico or whoever.
Re: wiper blade refill source [Re: kentj340] #1498182
09/09/13 07:14 AM
09/09/13 07:14 AM
Houston, Tx
Houston, Tx
Yes,,,, that's the problem. I'm not having any success finding the refills, don't want the blade holder... Looking for a source for the rubber refills......
Troy
Re: wiper blade refill source [Re: hemi68charger] #1498183
09/09/13 01:10 PM
09/09/13 01:10 PM
Houston, Tx
Houston, Tx
I have googled 16" and have gotten some ANCO and Trico hits, but there are a wide selection of possibilities... Anyone recently purchased any refills and have the part number?
Thanks..
Troy
Re: wiper blade refill source [Re: hemi68charger] #1498184
09/09/13 01:22 PM
09/09/13 01:22 PM
SC
Cooda Offline
Cooda  Offline
SC
These should fit the factory 16" blades.
Anco Wiper Blade Insert - Front
Your Price: $5.10
Quantity:
Qty Available: 20
(20) In Stock Part Number: 14530-07065889
See this URL http://www.partsgeek.com/catalog/1970/dodge/challenger/body_electrical/wiper_blade.html
Re: wiper blade refill source [Re: hemi68charger] #1498185
09/09/13 08:33 PM
09/09/13 08:33 PM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
I get them from Rock Auto...
http://www.rockauto.com/catalog/moreinfo.php?pk=532565
Don't forget to use the discount code...
Re: wiper blade refill source [Re: idrivevintage] #1498186
09/10/13 08:00 AM
09/10/13 08:00 AM
Houston, Tx
Houston, Tx
Thanks guys. Friend bought a pair of replacement wipers from YearOne, so I just took the actual wipers out and inserted those into his original blade holders. Thank you for your input.
Cheers
Troy
Re: wiper blade refill source [Re: hemi68charger] #1498187
09/10/13 11:14 AM
09/10/13 11:14 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
After looking for the same thing, what I found out is you can get refills that will work,BUT there not correct. The little red button used to release the refills won't work on whats readily available. They look ok and function ok, but just won't release like they are supposed to. But if you have several hundred dollars, NOS ones are out there on ebay.
Re: wiper blade refill source [Re: hemi68charger] #1498188
09/10/13 04:32 PM
09/10/13 04:32 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
If your looking for nos, I have some 15" Trico refills.
Re: wiper blade refill source [Re: hemi68charger] #1498189
09/11/13 02:20 AM
09/11/13 02:20 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
To be more specific, what I meant was to remove the rubber from the stainless flat piece (arrow), and install new rubber. This is a bit tedious, but what is available at car parts stores now is often mounted in plastic or other. All you need to worry with is the right profile of the rubber...
Re: wiper blade refill source [Re: 52savoy] #1498190
09/11/13 01:25 PM
09/11/13 01:25 PM
Houston, Tx
Houston, Tx
Thanks for the offer..... I appreciate it..... But, we found what we were looking for......
The blades Hoss bought at the same metal frame/retainer as that pictured in your reply, so I just swapped out his old ones for the new ones, perfect.....
Troy
Re: wiper blade refill source [Re: hemi68charger] #1498191
09/12/13 06:32 PM
09/12/13 06:32 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
If you are looking for refills (not complete blades) at stores like Autozone and O'Reilly, you won't find them on the shelves. You have to ask the counter person for the "refills", as they hide them in the back (so they can sell you replacement blades for 6X the cost).
Sucks as the blades don't fit under most hoods on models with hideaway wipers.
You can take them apart as you like and swap the parts around.
When you work on Spaceships for a living, how bad can a workday be?
