Distributor gear slot not lining up EXACTLY centerline #1496142
09/04/13 02:07 PM
09/04/13 02:07 PM
Kyle, Tx
joeblow Offline OP
joeblow  Offline OP
Kyle, Tx
Ok.. I've put a new stock cam into a '70 440, and when I drop the distributor drive gear in place, the slot doesn't run "exactly" centerline with the cam/crank.
The slot in the gear is supposed to be parallel to the cam/crank... right ?
The timing chain is lined up right on the money, and I've double checked it as well.
Anyway, the slot is slightly tilted up, or down with which ever way the gear is mated up to the cam.
QUESTION: Will this matter a great deal, and can the distributor be rotated in the timing to make up for the slight mis-alignment ? And, Is there a better way of the slot being tilted that would be better, if that's the case ?
I'm sure I'm not the first to run across this issue, so any advise will be greatly appreciated
Re: Distributor gear slot not lining up EXACTLY centerline [Re: joeblow] #1496143
09/04/13 02:18 PM
09/04/13 02:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Sometimes you can turn the cam a bit to get the gear to align better.Its nor a big deal if not perfect.You can usually turn the dist enough to make up for it.Rocky
Chrysler Firepower
Re: Distributor gear slot not lining up EXACTLY centerline [Re: joeblow] #1496144
09/04/13 02:18 PM
09/04/13 02:18 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Does not matter...put engine on #1 tdc firing...and line the rotor and #1 on the distributor cap...
you can have the slot facing the moon...as long as #1 on the cap and rotor line up...
and as long as the distributor cam be moved back n forth to adjust the timing...sometimes the vacuum canister gets in the way.
Tony
70 AARCuda Vitamin C
Re: Distributor gear slot not lining up EXACTLY centerline [Re: joeblow] #1496145
09/04/13 02:19 PM
09/04/13 02:19 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Won't matter assuming you have the #1 piston at TDC on the compression stroke. Now, drop in the distributor making sure the rotor is pointing to the #1 plug wire tower and you'll be in the ball park.
Really wouldn't matter where that intermediate shaft were installed as long as the distributor rotor is pointing to the #1 plug wire.
Re: Distributor gear slot not lining up EXACTLY centerline [Re: 70Duster440] #1496146
09/04/13 02:23 PM
09/04/13 02:23 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The actual answer is NO, it's not supposed to line up. Take a look in the FSM and there will be a picture. The other guys are also right...
Re: Distributor gear slot not lining up EXACTLY centerline [Re: Jim_Lusk] #1496147
09/04/13 02:27 PM
09/04/13 02:27 PM
Kyle, Tx
joeblow Offline OP
joeblow  Offline OP
Kyle, Tx
Thank you guys so much for the quick replies
Re: Distributor gear slot not lining up EXACTLY centerline [Re: joeblow] #1496148
09/04/13 05:56 PM
09/04/13 05:56 PM
get the dampener at ~20 BTDC #1 compression. With a 1&1/4" socket/breaker bar hand turn the crank clockwise a bit more till the slit is at your desired initial timing which might be 10 for a mild cam or 15 for a wild(er) cam. I'd suggest clocking the wires on the cap placing #1 in the OE location (helps prevent future mistakes) then clock the intergear ANYWHERE it needs to be so that with the vac can in its' correct general location (with room to be turned either way) then turn the housing slightly till the magnet is dead even with the tooth that places the rotor under or near under the #1 cap terminal & note that the vac adv will shift the rotor (rotor phasing) clockwise from that position (on a BB) when vacuum is applied to the can. putting the intergear slot parallel would be a good start then go from there but it can end up anywhere & some dizzys have vastly different bottom tang to top rotor clocking & what's important is the final rotor position.
Re: Distributor gear slot not lining up EXACTLY centerline [Re: RapidRobert] #1496149
09/05/13 01:46 AM
09/05/13 01:46 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The oil pump will mess with you on this. If the hex is off a few degrees either direction, the oil pump drive/distributor drive will not slide down into the exact position and be a tooth off either way.
I've had to pull the oil pump drive out and twist the oil pump a few degrees with the priming tool to get the distributor slot to line up.
Re: Distributor gear slot not lining up EXACTLY centerline [Re: Kern Dog] #1496150
09/05/13 11:01 AM
09/05/13 11:01 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Will someone please show a drawing or photo that shows the correct (factory( location of the vacuum advance when the distributor is correctly installed. Thanks!
Re: Distributor gear slot not lining up EXACTLY centerline [Re: MO_PA] #1496151
09/05/13 02:25 PM
09/05/13 02:25 PM
3rd rock
K
kloyiod Offline
kloyiod  Offline
K
3rd rock
The vacumm can should point towards the opposite back at about the 12 O'clock position. You can google mopar engines and look at pictures as well.
Re: Distributor gear slot not lining up EXACTLY centerline [Re: joeblow] #1496152
09/05/13 03:39 PM
09/05/13 03:39 PM
I've put a new stock cam into a '70 440, be greatly appreciated
If you left it dot to dot (6&12 o'clock) don't forget to locate the rotor under #6 cap terminal
Re: Distributor gear slot not lining up EXACTLY centerline [Re: MO_PA] #1496153
09/05/13 04:49 PM
09/05/13 04:49 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is where it should be !
Re: Distributor gear slot not lining up EXACTLY centerline [Re: 62maxwgn] #1496154
09/05/13 10:46 PM
09/05/13 10:46 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Thanks again!!
Re: Distributor gear slot not lining up EXACTLY centerline [Re: 62maxwgn] #1496155
09/06/13 12:00 PM
09/06/13 12:00 PM
Max which wire is #1 in the pic (assuming it is in the correct OE cap terminal location)
Re: Distributor gear slot not lining up EXACTLY centerline [Re: RapidRobert] #1496156
09/06/13 12:53 PM
09/06/13 12:53 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The 5 o'clock position, where the wire goes to the other bank.
Joe
Re: Distributor gear slot not lining up EXACTLY centerline [Re: jlatessa] #1496157
09/06/13 12:56 PM
09/06/13 12:56 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Whoops, I guess I wasn't supposed to answer that!
