BB 11" manual drum brakes #1495291
09/02/13 07:47 PM
09/02/13 07:47 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
What exactly should manula drum brakes feel like? I have manual drum all the way around on my 68 charger, and the pedal goes almost to the floor unless pumped. I adjusted the shoes at all corners and its better, to the point where the brake warning light does not come on...the rears were way out. It's a reman master cylinder, and I have all new lines (soft and hard) plus all new wheel cylinders. The proportioning valve was disassembled and cleaned. No leaks anywhere, is this just how it is?
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495292
09/02/13 08:23 PM
09/02/13 08:23 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Bleed your system again. Manual brake systems dont have proportioning valve, they have distrubition blocks..
I am truckless..
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495293
09/02/13 09:26 PM
09/02/13 09:26 PM
What exactly should manula drum brakes feel like? No leaks anywhere, is this just how it is?
Properly set up(adjusted and bled) should have a rock hard peddle 1/4 to 1/3 of peddle travel from top It sounds like you still have some air in the brake system Start by bleeding the left front brake and then the R/F, next the left rear(don't forget to keep the master cylinder at least half full of brake fluid at all times ) If a wheel cylinder spits out fluid and then air bleed that cylinder until only fluid comes out Keep the fliud level in the master cylinder full for each cylinder bleeding Good luck
Re: BB 11" manual drum brakes [Re: Cab_Burge] #1495294
09/03/13 11:33 AM
09/03/13 11:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cab thats backwards from all bleed sequinces Ive ever read.You always start RR then LR then the fronts.Only one differnt Ive done in over 40 years was the split diag systems.Then it was RR LF LR then RF.Rocky
Chrysler Firepower
Re: BB 11" manual drum brakes [Re: therocks] #1495295
09/03/13 11:42 AM
09/03/13 11:42 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
when i was younger i bled brakes in no particular order and they were fine.but sayin "WHOA NELLY BELL"was a different time and somtimes slow to react.
Re: BB 11" manual drum brakes [Re: therocks] #1495296
09/03/13 02:21 PM
09/03/13 02:21 PM
Your probally correct on the recommended sequence, I have always done things different My memory sucks OP, another easier way to bleed them is to use the gravity method(as long as the mater cylinder is above the wheel cylinders this will work) which involves opening one bleeder screw at a time and let it drip out for a while, not under pressure This method works fine as long as your not in a hurry, you can also put a piece of rubber tubing over the bleeder screws and put the other end in a glass jar or cup to catch the brake fluid so it doesn't eat up the paint on the backing plates and run down onto the wheels and tires
Re: BB 11" manual drum brakes [Re: Cab_Burge] #1495297
09/03/13 02:22 PM
09/03/13 02:22 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Properly set up(adjusted and bled) should have a rock hard pedal 1/4 to 1/3 of peddle travel from top
I'd agree with that...
Describes mine...
DOT 5 fluid...Shoes adjusted...
I bleed from the furthest point back...
Re: BB 11" manual drum brakes [Re: RSNOMO] #1495298
09/03/13 03:43 PM
09/03/13 03:43 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
The sequence Cab recommended sounds backwards to me as well, but I recently heard/read somewhere else to do it that way. I always start furthest from the MC and work my way closer and I've never had a problem.
Pedal should be rock hard only slightly depressed, as described. You will never get these things anywhere near the floor once all setup correctly and bled.
Re: BB 11" manual drum brakes [Re: GTX MATT] #1495299
09/03/13 06:23 PM
09/03/13 06:23 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Bleed em again Paul. Must have air in the lines.
Re: BB 11" manual drum brakes [Re: Pntastar69] #1495300
09/08/13 10:06 PM
09/08/13 10:06 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Bought a HF power bleeder, seems like I'm not getting fluid to the front wheels, going to disconnect and blow out with air. What a PIA
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495301
09/09/13 05:11 AM
09/09/13 05:11 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
On my 68 Charger I had new hoses that did not let the fluid pass through. I even tried to run a steel rod through them, OK, but It seemed like the ordinary brake fluid made them swoll and tighten up inside. I ended up installing the old hoses again, then it all worked out perfectly. The new hoses were made in India. My
Re: BB 11" manual drum brakes [Re: Oyvind Mopar] #1495302
09/09/13 09:30 AM
09/09/13 09:30 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Are you sure you have the shoes adjusted correctly? If they are too far out of adjustment, the wheel cylinder runs out of travel before the shoes contact the drum and you have to pump it for more travel. The 11" on my cars are manual adjust, not self adjust, so they won't fix themselves like on most other brakes.
You mention the brake light coming on before you adjusted them last. I didn't think adjusting the brakes would have anything to do with the light, it's supposed to light up when there's a hydraulic problem.
If a brake re-adjust and re-bleed doesn't fix it, I'd try a new MC.
Re: BB 11" manual drum brakes [Re: B5 Bee] #1495303
09/09/13 06:31 PM
09/09/13 06:31 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Yep all 4 wheels are adjusted. With the power bleeder I cab barely pull anything at the front wheels. Hoses are new from summit but I will test them. Master cylinder was replaced by them once already, it's gotta be the hoses or something in the front lines.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495304
09/09/13 08:07 PM
09/09/13 08:07 PM
northern illinois
jburt Offline
jburt  Offline
northern illinois
just wondering what was all done to the brake system? did the pedal ever feel good for you before or did you get the car that way? was the master push rod ever changed with a wrong one?
Re: BB 11" manual drum brakes [Re: jburt] #1495305
09/10/13 10:36 PM
09/10/13 10:36 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Car was off the road since 83. I think it may be the front rubber lines, I'll find out Thursday morning.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495306
09/10/13 10:56 PM
09/10/13 10:56 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Don't even mess with 'em...
Replace 'em...
Re: BB 11" manual drum brakes [Re: RSNOMO] #1495307
09/12/13 01:45 PM
09/12/13 01:45 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
I'm stumped. All new hard lines, soft lines, wheel cylinders, and on a second master cylinder from Summit.
I pulled a rubber line on the front and was able to draw a solid line of fluid from the hard line; I then placed the rubber line in a container and was able to pull solid fluid through it. I put it back together and I can only get a trickle from the front bleeder screws. I can't imagine I need a thread sealer on the bleeder screws!
Is it possible there is an issue with the junction block not working correctly? After all of this I still have to pump the brakes multiple times to build any pressure, it makes 0 sense. When I bled the rear I was able to pull solid fluid, at least one side.
There are no leaks yet I can't pull a solid line at the front wheels. F'n baffled.
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495308
09/12/13 02:20 PM
09/12/13 02:20 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
Time to sell that POS '68 to me! LOL
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: BB 11" manual drum brakes [Re: Erik] #1495309
09/12/13 02:26 PM
09/12/13 02:26 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
hahaha never! I want to be buried in that car
Re: BB 11" manual drum brakes [Re: MOPAULY] #1495310
09/12/13 02:38 PM
09/12/13 02:38 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
At this point, you've got good fluid flow to the wheel cylinders, but only one will bleed???
