Maintenance on sitting race car #1493118
08/30/13 02:47 AM
08/30/13 02:47 AM
fresno ca
mikeysmopars Offline OP
fresno ca
Havn't raced since March this year and plan to run in October.
Car has pretty much sat in the same spot for the last 6 months and i try to fire it a couple times a month to keep valve springs rotated but what else is important? Before i run i plan to put a wrench on every nut & bolt & do typical go around but what do you guys do if it sits a while? Non alcohol just race gas, I'm in central California so weather isn't a factor.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Maintenance on sitting race car [Re: mikeysmopars] #1493119
08/30/13 10:59 AM
08/30/13 10:59 AM
Az
Crizila Offline
Crizila  Offline
Az
That's basically what I do also. My car sits for a few months during the hot weather in Az. I jack the rear tires off the ground. Fire it up a couple of times a month and dump it in gear and run the drive train a little. Since my car is still licensed, I do have a set of mufflers and short exhaust pipes ( exit in front of diff ) that I can easily ( band clamped to the collectors) put on and take off for short road tests if need be. I run race gas also so we don't have to sweat the fuel / alcohol issue.
Fastest 300
Re: Maintenance on sitting race car [Re: Crizila] #1493120
08/30/13 06:39 PM
08/30/13 06:39 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my car sits for 7 months of the year over our winter. when we park it up we back off the rocker gear so all the valves are seated. at restart it's fresh oil with a prime on the pump, change the trans fluid & radiator coolant. every 2nd year we flush the brake fluid. during winter we remove the valve springs & test them, so far we've figured springs are only good for 150 runs when we change retainers n locks as well. we have very few failures & run super consistant. we can tell what our dial in will be just by looking at the barometer.
Re: Maintenance on sitting race car [Re: rebel] #1493121
08/30/13 07:14 PM
08/30/13 07:14 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Sweet 300 in the back round
Re: Maintenance on sitting race car [Re: mikeysmopars] #1493122
08/30/13 08:23 PM
08/30/13 08:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here`s my routine............I start it, go for a drive maybe grab lunch then put it up. Register that damn thing and enjoy it.....
Re: Maintenance on sitting race car [Re: avenger572] #1493123
08/30/13 08:44 PM
08/30/13 08:44 PM
Az
Crizila Offline
Crizila  Offline
Az
Keen eye!
Fastest 300
Re: Maintenance on sitting race car [Re: Thumperdart] #1493124
08/30/13 08:48 PM
08/30/13 08:48 PM
Bakersfield Ca
jmoparman Offline
jmoparman  Offline
Bakersfield Ca
Race more
Re: Maintenance on sitting race car [Re: Crizila] #1493125
08/30/13 08:50 PM
08/30/13 08:50 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I used to fire mine up from time to time, but the last couple of years all I do is turn the crank with a breaker bar to move the valve springs. If it sits long enough, I'll pre-oil it before lighting it off. Haven't noticed any problems. Before taking it to the track, I go over the fasteners, fluids, wheels & tires to make sure it's ready.
Re: Maintenance on sitting race car [Re: Thumperdart] #1493126
08/30/13 08:56 PM
08/30/13 08:56 PM
fresno ca
fresno ca
You sound just like my buddy. I have enough stuff to drive on the street. I prefer to keep the two separate as i'm not as Law abiding as you Dom.
Re: Maintenance on sitting race car [Re: jmoparman] #1493127
08/30/13 08:59 PM
08/30/13 08:59 PM
fresno ca
fresno ca
Race more
Speak Of the Devel!
Re: Maintenance on sitting race car [Re: mikeysmopars] #1493128
08/30/13 09:01 PM
08/30/13 09:01 PM
Bakersfield Ca
jmoparman Offline
jmoparman  Offline
Bakersfield Ca
You're buddy's a smart man
Re: Maintenance on sitting race car [Re: avenger572] #1493129
08/30/13 09:01 PM
08/30/13 09:01 PM
Az
Crizila Offline
Crizila  Offline
Az
Also nice wheels. Here is a very rare set Anson's I believe.
Fastest 300
Re: Maintenance on sitting race car [Re: Crizila] #1493130
08/30/13 10:16 PM
08/30/13 10:16 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Another pic
Re: Maintenance on sitting race car [Re: mikeysmopars] #1493131
08/31/13 12:25 AM
08/31/13 12:25 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You could make it work.............. We`ll pass on the "Law" stuff for now thank you.
