How often(# passes) do you Change oil in your racecar? #1492038
08/28/13 04:39 PM
08/28/13 04:39 PM
Penna
70satelliteguy Offline OP
Penna
I have been changing mine and running the valves after 25 passes for years. Recently I have talked with other racers that change 1-2 times a year or one guy that thinks he needed to change it every outing
. I can usually smell the 112 Sunoco on the dipstick after one time at the track but the oil is still clean! I race almost every Friday night all summer and put about 100 passes on a year so that amounts to 4 oil changes
What do you guys do? Am I throwing good oil away after 25 passes?
My bearing look good from one year to the next but I usually change them out every 3 years along with the rings.
Thanks Mike
Re: How often(# passes) do you Change oil in your racecar? [Re: 70satelliteguy] #1492039
08/28/13 04:51 PM
08/28/13 04:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
20-30 pass's for me. sounds like you are doing the right thing.. why change something that works good?
Re: How often(# passes) do you Change oil in your racecar? [Re: VernMotor] #1492040
08/28/13 04:56 PM
08/28/13 04:56 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Two times a year.
Re: How often(# passes) do you Change oil in your racecar? [Re: VernMotor] #1492041
08/28/13 04:58 PM
08/28/13 04:58 PM
P
Paul_Fancsali Offline
P
Change it every 10 passes and use that oil in street car > Depending on conditions but if the air at track is dusty and smoky I would change it more often then waiting for set number of passes. The second I smell fuel in oil out it goes
Re: How often(# passes) do you Change oil in your racecar? [Re: sshemi] #1492042
08/28/13 05:00 PM
08/28/13 05:00 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Two times a year.
That it is with alot of street driving
Re: How often(# passes) do you Change oil in your racecar? [Re: 70satelliteguy] #1492043
08/28/13 05:00 PM
08/28/13 05:00 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I change mine about 75 passes, but I have a 10 qt system (9 qt Milodon SS pan, a Wix filter that holds just under 1 qt, a remote filter set up and external oil line). It is not unusal for me to make 20-some passes in a weekend. With oil, filter and additive, a change cost around $75 for me, plus getting rid of 10 qts used oil.
Brian
Re: How often(# passes) do you Change oil in your racecar? [Re: '72CudaRacer] #1492044
08/28/13 07:09 PM
08/28/13 07:09 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Every 50 passes. I average 20 passes a weekend.
Re: How often(# passes) do you Change oil in your racecar? [Re: Dabee] #1492045
08/28/13 07:17 PM
08/28/13 07:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
buy you guys must just love to change oil I would guess and say at least a 100 passes probably closer to 150. 2 times a year
Re: How often(# passes) do you Change oil in your racecar? [Re: Quicktree] #1492046
08/28/13 07:25 PM
08/28/13 07:25 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've got 60 on mine right now.
Doug
Re: How often(# passes) do you Change oil in your racecar? [Re: Quicktree] #1492047
08/28/13 07:25 PM
08/28/13 07:25 PM
Amherst,NY
challengermike Offline
Amherst,NY
1 time a year for me. For 150 passes that's only 37.5 street miles if you running the quarter mile or 75 miles including the return road.
Re: How often(# passes) do you Change oil in your racecar? [Re: challengermike] #1492048
08/28/13 08:01 PM
08/28/13 08:01 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I check mine for fuel comtamination, if it looks good once a year, I agree with above, at allmost any track a pass is 1/2 mile.Ive had good friends that change after every race, no matter if they went 3 passes or 6, just never saw the need if your running race gas, alcohol would be differnt, not sure about E 85?
Re: How often(# passes) do you Change oil in your racecar? [Re: wyoming] #1492049
08/28/13 08:29 PM
08/28/13 08:29 PM
gregsdart Offline
gregsdart  Offline
I run alky, and it stays so fresh and clear I doubt I have ever needed to change it, but do so once a year.
Re: How often(# passes) do you Change oil in your racecar? [Re: gregsdart] #1492050
08/28/13 08:35 PM
08/28/13 08:35 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
The Super Street car I change it every 30ish passes. Always looks great but the way I see it oil is cheap and it might help me see something going on before it gets bad. On the Hot Street car with the 99 hemi we have been known to change it twice in a weekend. Occasionally if we think we need that extra .02 or .03 we will throw in the thin stuff, but thin I mean 0W5. Usually the car runs a little thicker oil in it. But it is a heads up all motor deal so ya gotta do what ya gotta do.
Re: How often(# passes) do you Change oil in your racecar? [Re: 70satelliteguy] #1492051
08/28/13 09:39 PM
08/28/13 09:39 PM
Az
Crizila Offline
Crizila  Offline
Az
once a year, whether it needs it or not. Run full synthetic and a $10 oil filter. Drain oil often goes in my beater.
Fastest 300
Re: How often(# passes) do you Change oil in your racecar? [Re: Crizila] #1492052
08/29/13 01:17 AM
08/29/13 01:17 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
after 50 runs. i use Royal Purple & usually by the time it gets to 50 runs it's lost it's purple shine & has become redish. 12 quarts in my system.
Re: How often(# passes) do you Change oil in your racecar? [Re: 70satelliteguy] #1492053
08/29/13 10:30 AM
08/29/13 10:30 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
After every run in my TAD and it holds 18 quarts because that's what it takes to keep oil in the pan with 60 pounds of boost.
Some times we would keep the oil around for a second run like the next day after it cooled.
The car always got cool fresh oil to go along with new upper rod bearings for each run.
Like if we had to start the car a extra time in the pit's then the oil definitely got dumped after one run.
I raced TAD for 8 years and only started the car twice at the shop, always waited until we got to the track to start a fresh engine because of the fuel system being drained after each weekend and the cost of oil and everything else like bearings and spark plugs.
Re: How often(# passes) do you Change oil in your racecar? [Re: 70satelliteguy] #1492054
08/29/13 10:43 AM
08/29/13 10:43 AM
Indiana
N
nssracer1 Offline
nssracer1  Offline
N
Indiana
20 runs on the DragnWagn. Like to see inside that System One filter to make sure everything is OK.
Re: How often(# passes) do you Change oil in your racecar? [Re: Challenger 1] #1492055
08/29/13 12:54 PM
08/29/13 12:54 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
With EFI you can get 3-4 runs using methanol and boost. That's about how often we change ours'.
Re: How often(# passes) do you Change oil in your racecar? [Re: BobR] #1492056
08/29/13 01:00 PM
08/29/13 01:00 PM
Cincinnati, Ohio
Cincinnati, Ohio
