Page 1 of 3 1 2 3
Soooooo close to the 9's!!!!! #1490157
08/25/13 09:40 AM
08/25/13 09:40 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well still at the Norwalk NMCA race today, but thought I'd put a quick post up for an update.
Headed here Friday with a plan to go for the gusto and run the true street 10.0 class. Last time out the car ran 10.27@132 on 16psi with a 1.53 60ft. Knowing it was gonna need more I put the 20psi tune up in it and headed for the track.
I had a REALLY hard time getting the car to hook. Just kept ripping the tires right at the TB realese. Finally on the 7th pass I had the thing backed all the way down to 7psi and 3200 on the two step.
Finally hooked with a anemic 1.61 60ft, but let me tell you the 20psi almost made up for it down track.
10.08@136
Sooooo close!!!! Really fast in the middle, just shy of 110mph at the 1/8th.
Went back up for another run with a bit more boost on the starting line hoping for a 9.99. Well the driver (me) made a boo boo.... when I staged the car it wasn't quite in far enough so I had to bump the trans brake once to roll it in. Which was fine EXCEPT for the fact that when I did that the boost controller thought I was starting the run. So while I was waiting for the lights to come down, the boost controller had started to ramp the boost in from 8psi to 20psi. So by the time I let go if the button it was at 20psi of boost!
Well the picture pretty much says it all...lol
That was the end of my weekend. No 9 sec time slip for now.
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490158
08/25/13 10:03 AM
08/25/13 10:03 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
So close! Work on your short time. You are making plenty of power. Get some very good shocks all the way around and have the valving on the rears modified for a dr car. Trust me, it helps!
Kinda like you, now that i have 1/2 of the stuff done, im now going to increase my boost like you did. we will see each other in the 9's very soon!
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490159
08/25/13 10:51 AM
08/25/13 10:51 AM
Mo.
racerx Offline
racerx  Offline
Mo.
What rearend was this?Looks like u r making some power
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490160
08/25/13 11:15 AM
08/25/13 11:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bummer you broke your 8 3/4.... it must have tried
to hook to tear the pinion in half
Re: Soooooo close to the 9's!!!!! [Re: TheOtherDodge] #1490161
08/25/13 11:19 AM
08/25/13 11:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
getting there... at least it didn't comne up thru the floor and mess a bunch of stuff up.
Coming soon!!!!
Re: Soooooo close to the 9's!!!!! [Re: Mr.Yuck] #1490162
08/25/13 11:34 AM
08/25/13 11:34 AM
this world
drifter Offline
drifter  Offline
this world
is there a chance the sprag might be hurt in the trans from this?
Re: Soooooo close to the 9's!!!!! [Re: drifter] #1490163
08/25/13 11:41 AM
08/25/13 11:41 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
oh yeah!
Re: Soooooo close to the 9's!!!!! [Re: drifter] #1490164
08/25/13 11:41 AM
08/25/13 11:41 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That thing is making some snot! How does your boost control work in conjunction with the TB? Time for a Dana?
Re: Soooooo close to the 9's!!!!! [Re: WO23Coronet] #1490165
08/25/13 12:41 PM
08/25/13 12:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
X2
And that thing is really trying to run....I want one.
Re: Soooooo close to the 9's!!!!! [Re: Dragula] #1490166
08/25/13 12:50 PM
08/25/13 12:50 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Dead stock 8 3/4" with a used 3.23 gear (742 case). Can't blame it for not holding up!
TB release triggers the boost ramp to start. I had it set on this pass to go from 8psi to 20psi in 0.7s.
Sprag could definitely be hurt, that's why I didn't try to fix it at the track. I had a buddy coming sat. morning that could have brought a gear, but I didn't want to chance the trans.
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490167
08/25/13 08:11 PM
08/25/13 08:11 PM
ohio
all spooled up Offline
ohio
wow thaTS MAKING SOME steam
what u going do for a rear end now
i was just asking about you and the turbo taxi
i got mine back together got boost now still has some carb problems
Re: Soooooo close to the 9's!!!!! [Re: all spooled up] #1490168
08/25/13 09:58 PM
08/25/13 09:58 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
I'm actually going to put the the 2.76 gear back in it. Talked to lots of NMCA drag radial guys this weekend and they all said its got way too much starting line ratio.
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490169
08/25/13 10:53 PM
08/25/13 10:53 PM
Detroit, Michigan
sbsatellite Offline
sbsatellite  Offline
Detroit, Michigan
2.76....I guess I need to off my 4.57 gear
Re: Soooooo close to the 9's!!!!! [Re: sbsatellite] #1490170
08/26/13 08:51 AM
08/26/13 08:51 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Holy Cannoli you did a whale of a job on that pinion
Sorry for the breakage, hope you get it back together without too much effort and expense
Re: Soooooo close to the 9's!!!!! [Re: roadhazard] #1490171
08/26/13 03:06 PM
08/26/13 03:06 PM
IL
furious70 Offline
furious70  Offline
IL
20psi on the 2.76 would be a loooooooooooong lever arm! (I know you won't do that again on purpose)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Soooooo close to the 9's!!!!! [Re: furious70] #1490172
08/26/13 03:12 PM
08/26/13 03:12 PM
COLUMBUS, OH
W
Whompin_Wedge Online content
Whompin_Wedge  Online Content
W
COLUMBUS, OH
That thing is sweeeett Scott!!
9's are just around the corner, even with the 2.76!!
Casey
Re: Soooooo close to the 9's!!!!! [Re: Whompin_Wedge] #1490173
08/26/13 03:31 PM
08/26/13 03:31 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think the 2.76 would be worse...meaning under more stress than the 3.23's...
Re: Soooooo close to the 9's!!!!! [Re: Mr.Yuck] #1490174
08/26/13 03:57 PM
08/26/13 03:57 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
2.76 will definitely be harder on the pinion, but I don't think any 8 3/4" is going to survive the accidental 20psi launch!
Re: Soooooo close to the 9's!!!!! [Re: dizuster] #1490175
08/26/13 04:53 PM
08/26/13 04:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You might want to up grade to a nodular unit center section and a nice ring/pinion set. I'm going to backbrace my 8.75 before I hit it w/ a 150 shot.
Re: Soooooo close to the 9's!!!!! [Re: Mr.Yuck] #1490176
08/26/13 06:02 PM
08/26/13 06:02 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
The lowest aftermarket ring and pinion made anymore is 3.55
Page 1 of 3 1 2 3
