Soooooo close to the 9's!!!!!
#1490157
08/25/13 09:40 AM
08/25/13 09:40 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well still at the Norwalk NMCA race today, but thought I'd put a quick post up for an update. Headed here Friday with a plan to go for the gusto and run the true street 10.0 class. Last time out the car ran 10.27@132 on 16psi with a 1.53 60ft. Knowing it was gonna need more I put the 20psi tune up in it and headed for the track. I had a REALLY hard time getting the car to hook. Just kept ripping the tires right at the TB realese. Finally on the 7th pass I had the thing backed all the way down to 7psi and 3200 on the two step. Finally hooked with a anemic 1.61 60ft, but let me tell you the 20psi almost made up for it down track. 10.08@136Sooooo close!!!! Really fast in the middle, just shy of 110mph at the 1/8th. Went back up for another run with a bit more boost on the starting line hoping for a 9.99. Well the driver (me) made a boo boo.... when I staged the car it wasn't quite in far enough so I had to bump the trans brake once to roll it in. Which was fine EXCEPT for the fact that when I did that the boost controller thought I was starting the run. So while I was waiting for the lights to come down, the boost controller had started to ramp the boost in from 8psi to 20psi. So by the time I let go if the button it was at 20psi of boost! Well the picture pretty much says it all...lol That was the end of my weekend. No 9 sec time slip for now.
Re: Soooooo close to the 9's!!!!!
[Re: drifter]
#1490163
08/25/13 11:41 AM
08/25/13 11:41 AM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
is there a chance the sprag might be hurt in the trans from this?
oh yeah!
[Re: WO23Coronet]
#1490165
08/25/13 12:41 PM
08/25/13 12:41 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
That thing is making some snot! How does your boost control work in conjunction with the TB? Time for a Dana?
X2
And that thing is really trying to run....I want one.
[Re: dizuster]
#1490167
08/25/13 08:11 PM
08/25/13 08:11 PM
Posts: 1,049 ohio
all spooled up
ohio
wow thaTS MAKING SOME steam what u going do for a rear end now i was just asking about you and the turbo taxi i got mine back together got boost now still has some carb problems
