Re: 46rh is dead. It's ugly in there.
[Re: J_BODY]
#1490140
08/27/13 01:28 AM
08/27/13 01:28 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My raggedy old parts washer hasn't been used in 14 years. We resurrected it for this job. Greg (owner of the transmission) had an old 5 gallon can of kerosene that he donated to the cause. A good scrubbing got the planetary gear sets looking great. Now we need to do something about that valve body. I'm afraid to open the OD unit. Is the goo in the splines a good indication of what we're going to find or did the tight fit keep most of the solids out? Look at the servo spring in the background.
[Re: 360view]
#1490142
08/27/13 09:50 AM
08/27/13 09:50 AM
feets
Senior Management
Senior Management
Irving, TX
The kerosene is doing a fine job. It may take a little longer than other cleaners but it's a known entity with no hidden surprises.
We did find it a bit disturbing that the parts laying on the table actually stuck. Some of the snap rings had to be tapped sideways to break the bond. That servo spring in the second photo didn't want to be moved either. When pulled, it leaned over to the side before popping free.
It's just nasty.
[Re: feets]
#1490147
08/27/13 01:16 PM
08/27/13 01:16 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Is that damage on the front part of the drum? (Left side) What is that?
[Re: feets]
#1490150
08/27/13 03:20 PM
08/27/13 03:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
One wonders if he's got a trans cooler that bypasses the radiator cooler.
[Re: John_Kunkel]
#1490152
08/28/13 01:18 AM
08/28/13 01:18 AM
feets
Senior Management
Senior Management
Irving, TX
This isn't fluid mixing. This is fluid abuse. Best we can figure is that a previous owner used crappy fluid and never changed it. I got the overdrive section disassembled in the press. After it was in pieces on the bench I had to pry the spring away from the other parts. It was glued together with this goo. The Berryman's stuff helped free up the planetary gears more than the kerosene. The OD planetary set will need serious attention before getting a bath. So, what do you think? Mission Impossible?
[Re: feets]
#1490155
08/29/13 10:36 AM
08/29/13 10:36 AM
feets
Senior Management
Senior Management
Irving, TX
The valve body makes a great repository for sticky nasty goo. We worked on it until 11 last night. The valve body pieces and front pump housing are the only things needing to be defunked. I gave him a key to the shop so he can get over there and mess with it while I'm at work. With luck it'll start going back together tomorrow.
