Re: my E-85 experience. [Re: MR_P_BODY] #1488401
08/26/13 01:02 PM
08/26/13 01:02 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
buy an A/F guage, put in an O2 sensor and forget about "guessing" what it wants
maybe santa claus is listening.
Forget the A/F meter on a race car... you know to tune
for the fastest MPH... then if you want you can take
a A/F reading... there is no magic number to tune to
If I were to do anything I think I would concider a pyrometer and tune by egt, but untill then I am going to tune by coolant temp rise and like you said,,MPH, if I were running the snot out of it every weekend then I may be more enclined to get into the o2 and A/F sensors and such, but that just not in the budget at this time.
Re: my E-85 experience. [Re: dartman366] #1488402
08/26/13 05:27 PM
08/26/13 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill...when you get it tuned in for best MPH you
will most likely see a 20 degree temp increase in
the 1/4
Re: my E-85 experience. [Re: MR_P_BODY] #1488403
08/26/13 05:35 PM
08/26/13 05:35 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Mr P most of the tuning i have done with an O2 watching H2O temp shows 8-12* to be the right tune. On the combos I have logged O2 on this puts lambda at .80-.82 which is where you want to be for a quick consistent tune.
Re: my E-85 experience. [Re: ajcasini] #1488404
08/26/13 05:42 PM
08/26/13 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What temp do you leave at... I think I was leaving
a bit too cold... I should have been near 180-185
Re: my E-85 experience. [Re: MR_P_BODY] #1488405
08/26/13 06:16 PM
08/26/13 06:16 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Most cars like 170. I have run mine as low 160 and high as 180 with no real performance change.
Normal runs in the heat of summer leave 170 go through a tick above 180. In the spring and call leave at 170 go through a tick below 180.
Re: my E-85 experience. [Re: ajcasini] #1488406
08/26/13 06:26 PM
08/26/13 06:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats why I said 20* increase... I was leaving at 160*
and seen 180* at the end.. most of the E-85 guys I've
talked with found that they made more power leaving
at a 180* temp... some even at 185*... I never tried
the higher temps myself but plan on trying it
Re: my E-85 experience. [Re: MR_P_BODY] #1488407
08/26/13 07:10 PM
08/26/13 07:10 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Gotcha.
I haven't seen much performance running it really hot before. Normally no change or a hair slower. The hottest I think I could make mine with no fan running was about 185.
Re: my E-85 experience. [Re: ajcasini] #1488408
08/26/13 07:17 PM
08/26/13 07:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
I'm usually doing my burnout without the fan off to bring it up to 165ish. I've never seen an increase in power running hotter or colder than that.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: my E-85 experience. [Re: Triple Threat] #1488409
08/26/13 10:21 PM
08/26/13 10:21 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
There is no way in hell that I would tune a/f off of water temp change. All radiator sizes are different, fans are different, water pumps flow different. How could anyone possibly do that from car to car?
Re: my E-85 experience. [Re: dizuster] #1488410
08/26/13 10:36 PM
08/26/13 10:36 PM
PA
ajcasini Offline
ajcasini  Offline
PA
The water temp method is effective for some. Others it may not work. I use it as a baseline to keep things safe. You still use normal tuning methods, plugs, MPH, split times, feel of the car.
Guys were tuning cars long before a/f gauges and it can still be done today.
Re: my E-85 experience. [Re: ajcasini] #1488411
08/26/13 10:45 PM
08/26/13 10:45 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Been tuning cars by the seat of my pants for 30 years. works just fine
Re: my E-85 experience. [Re: VernMotor] #1488412
08/26/13 11:23 PM
08/26/13 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have all of the fancy dandle stuff but I use it about
10% of the time... my A/F meter is used for cruise
A/F only.. I tune the race car on the MPH... I never
seen the need for it on the race car... I set the idle
for where it idles best and WOT on the MPG
Re: my E-85 experience. [Re: MR_P_BODY] #1488413
08/27/13 02:07 AM
08/27/13 02:07 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Just switched to E85, and now it seems that there is excessive smoking present. http://www.youtube.com/watch?v=PPzIop6LpwA&feature=youtu.be
Plynouth VIP '67 TT IC EFI
Re: my E-85 experience. [Re: jyrki] #1488414
08/27/13 03:26 AM
08/27/13 03:26 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
yeah you better fix that before you pizz off the neighbors.
