cope shift R gate #1487247
08/20/13 07:10 AM
08/20/13 07:10 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
who here has one of these stuck on there slap stick? does it work ok? is it easy to fit? got any pics? https://www.coperacingtrans.com/images/Rgate.jpg
Re: cope shift R gate [Re: rebel] #1487248
08/20/13 07:20 AM
08/20/13 07:20 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I bought one for my 67 Satellite - but its not installed yet.
Re: cope shift R gate [Re: Cudafied] #1487249
08/21/13 08:44 AM
08/21/13 08:44 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I thought the whole idea of the shift-r-gate was to make early mopar shifters work like a slap stick? So I don't think one would be needed if you already had one.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: cope shift R gate [Re: MoparBilly] #1487250
08/21/13 01:24 PM
08/21/13 01:24 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
That's the one I installed in my car.
Based on the number on the side of it, it's made by Duncan Motorsports.
http://www.duncan-motor-sports.com/2.html
It doesn't work exactly like a factory slapstick.
Sometime I have problems shifting from park to reverse.
It doesn't want to come out of park easily sometimes.
The gate looks like it was cut out with a plasma cutter, kinda rough edges in it so it doesn't move smoothly even with grease on it.
I knocked down the extremely rough edges with a file to smooth it some.
Definitely not as smooth as the factory shifter gate plate.
Edit: Forgot to mention, mine is a reverse manual 727.
Re: cope shift R gate [Re: MoparBilly] #1487251
08/22/13 01:58 AM
08/22/13 01:58 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i bought one to make my slapstik work with reverse manual valve bodies, thats how they're advertised, just wanting to know if anybody is using one.
Re: cope shift R gate [Re: rebel] #1487252
08/27/13 07:31 AM
08/27/13 07:31 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i did the conversion & fitted the new gate. was pretty straight forward, just a little file up of the 1-2 ramp but so far it feels good. had to swap out a stronger spring on the shifter knob shaft as the old one wouldn't return to the top of the gate but that was pretty easy. can't wait to try it in battle.
as per factory
take the front plate off, thats the spring that was too weak.
find the bits you don't want, bit like gutting fish really.
say goodbye to the old gate
bolt it back together
lube it to death & you're done.
