That's the one I installed in my car.
Based on the number on the side of it, it's made by Duncan Motorsports.
http://www.duncan-motor-sports.com/2.html It doesn't work exactly like a factory slapstick.
Sometime I have problems shifting from park to reverse.
It doesn't want to come out of park easily sometimes.
The gate looks like it was cut out with a plasma cutter, kinda rough edges in it so it doesn't move smoothly even with grease on it.
I knocked down the extremely rough edges with a file to smooth it some.
Definitely not as smooth as the factory shifter gate plate.
Edit: Forgot to mention, mine is a reverse manual 727.
