Dual plug Hemi valve covers #1485475
08/17/13 03:42 AM
08/17/13 03:42 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Can someone fill in the measurements on this photo for me please, I can't find any of these plates so I need to make a set, Thanks
A - total length =
B - total width =
C - diameter of holes =
D - between centers =
E - thickness of plate =
F - thickness of rubber =
Re: Dual plug Hemi valve covers [Re: nz383man] #1485476
08/17/13 08:44 AM
08/17/13 08:44 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
If I make it down to the garage,I'l grab one and measure it up for ya
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Dual plug Hemi valve covers [Re: hemi-itis] #1485477
08/17/13 07:42 PM
08/17/13 07:42 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
Perhaps Cab Burge has another set laying around, that's where I got mine from. Make a set with 1 hole and ill swap you mine. I only have the single plug heads.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Dual plug Hemi valve covers [Re: BB65Barracuda] #1485478
08/17/13 09:07 PM
08/17/13 09:07 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Measured from Mopar stamped aluminum valve covers as shown in above photo.
A=3.190
B=1.550
C=1.270
D=1.640
E=.039
F=.006 Dipped rubber coating all over
Re: Dual plug Hemi valve covers [Re: maximus] #1485479
08/17/13 11:05 PM
08/17/13 11:05 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've seen these valve covers many time but just thought now , how are those dual / single plug plates sealed to the valve cover?
Re: Dual plug Hemi valve covers [Re: maximus] #1485480
08/17/13 11:46 PM
08/17/13 11:46 PM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
A=3.190
B=1.550
C=1.270
D=1.640
E=.039
Thanks for the measurements, that is exactly what I was liking for.
Interesting to see what you mean about the rubber coating from the pic above, I thought the factory ones were all two piece, alloy plate with separate rubber gasket like the pics below, maybe they made a couple of variants, any comments on which work the best? Thanks again.
Re: Dual plug Hemi valve covers [Re: nz383man] #1485481
08/18/13 07:31 AM
08/18/13 07:31 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
High Temp silicone seals them to the valve covers.
Re: Dual plug Hemi valve covers [Re: nz383man] #1485482
08/18/13 07:42 AM
08/18/13 07:42 AM
MICHIGAN
MICHIGAN
mine are rubber coated. I put a little silicone around the hole seal but not where it seats to the valve cover.
Once you install the tubes, orings and tighten down the plug they seal right up.
At least on my car they did.
Re: Dual plug Hemi valve covers [Re: BB65Barracuda] #1485483
08/18/13 07:48 AM
08/18/13 07:48 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
Thanks guys, this is my first Hemi build & maybe I could have started with something easier than an old dual plug Motown engine but why do things the easy way!
Re: Dual plug Hemi valve covers [Re: nz383man] #1485484
08/18/13 08:24 AM
08/18/13 08:24 AM
MICHIGAN
MICHIGAN
It's no different than any other motor with the exception of Goobs of torque on the cheap!
Mine is a 66 426 I bought along with my Drag Car, I did the correct machine work and put it together as I did any other motor and she rocks!
I put it in My wifes 65 Coronet and along with an appropriately built trans and brake upgrade we drove it in the Dream Cruise on Woodward last night and have made several 150 plus mile trips with it and its a blast.
Just a Gas Hog, and that's even keeping your foot out of it.
All the trinkets that go along with it are the Problem, carbs, headers, linkages, stamp 426 on it and all the A Holes come out of the woodwork to sell you what you need.
You can pick a lot of stuff up on the cheap if your not afraid to do a little tuning. If you are not trying to build a Concourse car You dont need the correct Carbs, they are Way overpriced.
Depending on what year you are working with, Mine uses the inline carbs. Mine are not Hemi correct but if you pull along side of me I bet you wouldn't know the difference.
But if you are wanting the correct parts and restoration info there are several guys on here that can supply you with all of the correct parts and tech help to make it less painful.
Re: Dual plug Hemi valve covers [Re: BB65Barracuda] #1485485
08/18/13 12:15 PM
08/18/13 12:15 PM
I am sorry fo not being able to reply sooner
I found the covers,cant find the part you needed measured.They gotta be around here somewhere
Re: Dual plug Hemi valve covers [Re: hemi-itis] #1485486
08/18/13 05:00 PM
08/18/13 05:00 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
two things happen when using those valve covers.
they will leak,they will crack at the bolt holes.
home of the
Sox and Martin Hemi Duster
Re: Dual plug Hemi valve covers [Re: HEMIFRED] #1485487
08/18/13 05:52 PM
08/18/13 05:52 PM
MICHIGAN
MICHIGAN
Ya but they look cool!
He's right about the leaking part.
I thought Hemis were supposed to leak?
Re: Dual plug Hemi valve covers [Re: BB65Barracuda] #1485488
08/18/13 07:35 PM
08/18/13 07:35 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
also, there is a little more power in the "B" = and it might help if you heli-arc weld inside the valve come, where the nut presses agains the inside and cause it to tear
Re: Dual plug Hemi valve covers [Re: StewartP] #1485489
08/18/13 07:52 PM
08/18/13 07:52 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
if you an find some valve cover spacers you seal them to the cover. now you have a flush solid surface which will not buckle when you tighten the nuts.
home of the
Re: Dual plug Hemi valve covers [Re: HEMIFRED] #1485490
08/18/13 10:10 PM
08/18/13 10:10 PM
OHIO
THE GLASS MAN Offline
OHIO
Fred, where would someone pick up a set of these "spacers"?
Re: Dual plug Hemi valve covers [Re: HEMIFRED] #1485491
08/19/13 05:03 AM
08/19/13 05:03 AM
New Zealand
nz383man Offline OP
nz383man  Offline OP
New Zealand
I can see exactly what you are saying here but how does the thickness of the spacer affect the length of the plug tube & how do you get around this?
Re: Dual plug Hemi valve covers [Re: nz383man] #1485492
08/19/13 07:07 AM
08/19/13 07:07 AM
MICHIGAN
MICHIGAN
Good Point!
Re: Dual plug Hemi valve covers [Re: BB65Barracuda] #1485493
08/19/13 10:23 AM
08/19/13 10:23 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Do yourself a favor and hang those on the wall and buy some cast 16 plug covers.
2011 Drag Pak Challenger
Re: Dual plug Hemi valve covers [Re: rickseeman] #1485494
08/19/13 04:04 PM
08/19/13 04:04 PM
MICHIGAN
MICHIGAN
I will say they are a lot easier to "Adjust" if your spring height goes over 1.88!
Soft stuff them covers!!
Ive not torn anything but I do use 1/4 20 studs and flat washer under the nut and snug them up good. I would agree over tightening a no no!
