How big of a transmission cooler do I need?
#1485426
08/16/13 11:48 PM
08/16/13 11:48 PM
Posts: 1,178 Indy
FlyFish
Indy
How big of a trans cooler do I need? Car is a 3200 lbs with driver, 90% race 10% street, 727, 8" converter, ~530 hp small block. I'm using the trans cooler that is in radiator currently...do I need more?
I just cooked the clutches in my trans, but it was 7 years old, so it was about due for a rebuild.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How big of a transmission cooler do I need?
[Re: Thumperdart]
#1485429
08/17/13 02:35 PM
08/17/13 02:35 PM
Posts: 1,178 Indy
FlyFish
Indy
I use a honey comb B&M from Kragens and has worked great for several years w/my big block, 727 and an 8" 5000+ stall vert..........never sees over 180 degrees...............
Roughly how big is yours (length, width, thickness)? Just trying to get an idea on how big of one I need to buy.
[Re: Thumperdart]
#1485432
08/17/13 03:13 PM
08/17/13 03:13 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
That B&M super cooler is an excellent tranny cooler. Beyond that step up to a derale with a fan mounted to it.
Mopar to the bone!!!
[Re: rebel]
#1485434
08/17/13 09:19 PM
08/17/13 09:19 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
2001 Dakota 5.2 Trailer Tow pack cooler.......fits exactly into a 22' rad opening. That sucker is COLD after the fan is running for 30 seconds.....Cheap and it works. Just get the line ends to the cooler when you pull it...makes hooking it up a breeze.
