dana from a truck for an A body #1484754
08/14/13 11:01 PM
08/14/13 11:01 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i want a dana for an A body where should i start looking? what year , truck, van, ford, dodge 1500, 2500 2wd,4wd ????
thanks gentlemen
Re: dana from a truck for an A body [Re: mcat4321] #1484755
08/14/13 11:30 PM
08/14/13 11:30 PM
thanks gentlemen
Nothing stock out of a van or truck I have ever heard of will bolt in and fit your car You will need to have one cut down and narrowed and have new axle bearing ends welded onto any of those units. Be careful onthe axle tube diameters, the stock Mopar Car Dan had three inch axle tubes, some of the early Dana 60-1 had 2.5 inch axle tubes Some of the early 3/4 ton trucks had three inch tubes also Some of the later 3/4 to trucks and one ton vans had 3 1/8 and some ahd 3 1/4 inch axle tubes Not so good to work with for narrowing on a stock leaf spring car I would take my time and try and find a good used core that has the gear ratio in it that you wnat, there are a lot of the later model trucks and vans that have 3.54 and 3.73 ratio in them as well as a bunch of 4.10 ratio out there I have bought a bunch of them over the years to use for narrowing, I have found perfectly good units with posi also
Re: dana from a truck for an A body [Re: Cab_Burge] #1484756
08/14/13 11:49 PM
08/14/13 11:49 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i should have specified.. i am aware that they will need cut to fit...
Re: dana from a truck for an A body [Re: mcat4321] #1484757
08/14/13 11:52 PM
08/14/13 11:52 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
what years should i be looking at?
Re: dana from a truck for an A body [Re: mcat4321] #1484758
08/15/13 12:46 AM
08/15/13 12:46 AM
I think a lot of the Pre 1970 Dana 60 3/4 ton truck and 1 ton van rear ends had the three inch axle tubes I use to ask the junkyards if they had any 3/4 ton truck rear ends with damaged axle ends for sale, I would tell them I neeed some of the parts from the insides
Re: dana from a truck for an A body [Re: Cab_Burge] #1484759
08/15/13 11:55 AM
08/15/13 11:55 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
For what is is worth, why not check with Doctor Diff here on the board and see what he would charge for a complete unit, set up and ready to install ??? He does great work and is great to deal with.
Cheers
Re: dana from a truck for an A body [Re: a12rag] #1484760
08/15/13 12:35 PM
08/15/13 12:35 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Cheers
Dr.Diff/Cass is great to deal with.
I bought my axles and driveshaft from him.
If you're starting from scratch and have none of the parts for the dana I would just buy a complete one from Dr.Diff.
I had a collection of new parts that I had been collecting for years (gears, power lock, etc.) to start with and in reality it was a royal pain in the rear.
It took 3 different dana 60 housings before I had a good one that I could use.
Re: dana from a truck for an A body [Re: SNK-EYZ] #1484761
08/15/13 08:20 PM
08/15/13 08:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
And be aware that most truck and van housing do not have provisions for pinion snubbers.
JB Rhinehart, Realist
A-Body's RULE!
Re: dana from a truck for an A body [Re: Rhinodart] #1484762
08/16/13 01:10 PM
08/16/13 01:10 PM
dogdays Offline
dogdays  Offline
And HOOGAS?
Pinion snubbers were a cheap crutch. There are better ways to plant the rear and keep it from rotating.
R.
Sorry, it's a knee-jerk reaction to the words "pinion" and "snubber".
Re: dana from a truck for an A body [Re: mcat4321] #1484763
08/16/13 01:19 PM
08/16/13 01:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I can promise you will be money and time ahead to call Dr diff or Moser.
I drove up to Moser and picked one up and got a tour of the place.
I would gladly buy from Dr Diff if he was closer.
Re: dana from a truck for an A body [Re: Challenger 1] #1484764
08/16/13 04:35 PM
08/16/13 04:35 PM
dogdays Offline
dogdays  Offline
In the Denver Area, Mark Williams is worth a call or a trip.
R.
Re: dana from a truck for an A body [Re: Challenger 1] #1484765
08/17/13 10:25 AM
08/17/13 10:25 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i been doing some research..moser are really proud of their stuff,even with the shipping from DR.DIFF, he is probably alot cheaper?
Re: dana from a truck for an A body [Re: mcat4321] #1484766
08/17/13 11:56 AM
08/17/13 11:56 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I can provide a new, bolt-in S-60 Dana 60 with Track-Lock for $1875. Upgrade to True-Trac $300. Freight runs about $200.
Most of my custom length 35 spline axle packages run $300 assembled, plus about $45 shipping.
You can research options and individual components on my website: www.doctordiff.com
Re: dana from a truck for an A body [Re: DoctorDiff] #1484767
08/17/13 01:54 PM
08/17/13 01:54 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you want disc brakes, use the ford torino ends and you can use the explored disc kit for 250, or if you use the small bearing ford ends, you can use the 2006 and up crown vic vented rotor rear brakes. Make sure who ever does the narrowing, they need to put the pinion angle 4* nose down because the perches are located on the forward third of the springs. Lessons learned.... the hard way.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: dana from a truck for an A body [Re: mcat4321] #1484768
08/19/13 02:47 AM
08/19/13 02:47 AM
Logansport, Indiana
Budman Offline
Budman  Offline
Logansport, Indiana
Theres a guy that does what you are wanting done just north of you. I have bought Dana 60 parts from him before. (937) 765-0911
Im going to have him set up my truck rear for my 67 Plymouth once its mini tubbed. He has disc brake kits to. Its definitely worth a call.
All MOPARS & nothig else.
