Question on fender mounted turn signals & inside arrows #1484301
08/14/13 10:22 AM
08/14/13 10:22 AM
ND
Birdlover Offline OP
ND
My wife's elderly uncle bought this 1967 Plymouth Fury VIP new and it now has 46,000 miles. It has fender mounted turn signals that do work, however the interior signal arrows do not. I looked under the dash and there are no lamp holders for the L & R arrows. This car is completely unmolested and I don't think there ever were lamp holders for the inside arrows. Can anyone verify this? Thanks.
1969 Road Runner, B7 Blue, 383, Auto
Re: Question on fender mounted turn signals & inside arrows [Re: Birdlover] #1484302
08/14/13 11:00 AM
08/14/13 11:00 AM
I'd think there'd have to be lamp holders for the bulb on each side to light up the 2 green arrows. But you wouldn't think both of em would have come undone & fallen out
Re: Question on fender mounted turn signals & inside arrows [Re: RapidRobert] #1484303
08/14/13 11:41 AM
08/14/13 11:41 AM
ND
ND
The wiring harness is as neat as the day it left the factory. The bulb holders for oil pressure light and high beam are plugged in where they are suppose to be. There is just no bulb holders anywhere for the L & R signal arrows (there are holes for them in the cluster panel). I'm stumped!
Re: Question on fender mounted turn signals & inside arrows [Re: Birdlover] #1484304
08/14/13 12:02 PM
08/14/13 12:02 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Are they powered by the circuit board? I know my '67 B-body ones are. They are just the little plastic pieces that twist into the board. It's possible he just didn't like the inside signals and pulled them out.
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Question on fender mounted turn signals & inside arrows [Re: Birdlover] #1484305
08/14/13 12:15 PM
08/14/13 12:15 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
In 1965 at least on Chryslers, when fender mounted turn indicators were ordered, the dash indicators were disabled. It was one or the other.
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Question on fender mounted turn signals & inside arrows [Re: Birdlover] #1484306
08/14/13 12:19 PM
08/14/13 12:19 PM
ND
ND
I don't believe they are powered by the circuit board. The other two aren't. Also, all the holes for the bulb holders are stamped with the wire color. The oil pressure and high beam bulb holders have the correct color wires going to them. The missing holes are stamped tan and green and these color wires are no where to be found.
Re: Question on fender mounted turn signals & inside arrows [Re: 300rag] #1484307
08/14/13 12:47 PM
08/14/13 12:47 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Correct. All Mopars that came with the fender mounted turn signals did not have a provision for the dash turn signals to work. I tried to add the bulbs and holders along with the fender signals and they wouldn't work. Even stopped the fender signals from working. I know this because I have had a 66 Chrysler 300 and now my 66 Plymouth Satellite with the fender signals. It is either/or but not both....
Re: Question on fender mounted turn signals & inside arrows [Re: CR8CRSHR] #1484308
08/14/13 07:34 PM
08/14/13 07:34 PM
nj
N
notforsale440 Offline
N
nj
been a while, but I think I remember the back of the cluster arrows had tape over them on my 68 GTX with fender mounted turn signals.........
Re: Question on fender mounted turn signals & inside arrows [Re: CR8CRSHR] #1484309
08/14/13 08:56 PM
08/14/13 08:56 PM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
My '72 and '75 Chryslers had both.
Steve
Someday I'll have another C-body.
Re: Question on fender mounted turn signals & inside arrows [Re: 300rag] #1484310
08/14/13 09:58 PM
08/14/13 09:58 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
My 66 Chrysler 300 had bulbs in the fender sockets, no bulbs in the dash sockets.
Re: Question on fender mounted turn signals & inside arrows [Re: notforsale440] #1484311
08/14/13 10:12 PM
08/14/13 10:12 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I had a survivor 70 sport satellite with fender signals, the in dash arrows did not work, I pulled the dash out and there was factory black tape over the holes. Not knowing any better I removed the tape, inserted sockets with bulbs and both worked together.
Re: Question on fender mounted turn signals & inside arrows [Re: Suregrip391] #1484312
08/14/13 10:33 PM
08/14/13 10:33 PM
nj
N
N
nj
yup....just looked at my cluster, first time in quite a while, lol............yes, black electrical type tape; keeps light from coming through the hole but also covers the bare copper connection on the circuit board......... I see no reason inserting bulbs wouldn't work
Re: Question on fender mounted turn signals & inside arrows [Re: Birdlover] #1484313
08/14/13 10:37 PM
08/14/13 10:37 PM
moparx Offline
moparx  Offline
tan and green may correspond to the ts switch colors.
Re: Question on fender mounted turn signals & inside arrows [Re: moparx] #1484314
08/14/13 11:25 PM
08/14/13 11:25 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I'm not 100% sure, but I'm pretty sure my '69 Road Runner with fender mounted indicators had functioning dash indicators, too. And I'm SURE the previous owner never fooled with anything on the car.
Re: Question on fender mounted turn signals & inside arrows [Re: Ramrod39] #1484315
08/15/13 01:49 AM
08/15/13 01:49 AM
Castlegar, BC, Canada
That AMC Guy Online content
That AMC Guy  Online Content
I've had several cars with fender-top turn signals. A '68 New Yorker, a '71 Swinger and a '75 Valiant Brougham. In all cases, both dash and fender-top lights worked in unison. This is actually the first I've heard of the one or other situation.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Question on fender mounted turn signals & inside arrows [Re: That AMC Guy] #1484316
08/16/13 09:40 PM
08/16/13 09:40 PM
arizona
stockerbill Offline
stockerbill  Offline
arizona
It is either/or but not both, not in all cases!. My 65 monaco has and always did have both! as with many things om old mopars"ya never know!
