Re: 93 to 95 difference?
[Re: 1E2C]
#1484042
08/13/13 09:30 PM
08/13/13 09:30 PM
Posts: 4,588 St. John's Newfoundland
440newport
I don't know the dimensional differences, but I've seen a few pics of 81-93 trucks with 94+ beds on them. From memory it looks like the wheel wells and over hangs are roughly in the same place, but because the old cabs taper in towards the top in a "fuselage" shape, the squarer, newer beds stick outside the cab along the beltline. If that helps any? I have a '90 W-150 shorty with a shot bed, and I've been thinking of putting on a newer style bed too because I can't find anything within 1000 miles of me.
[Re: 76dodgeboy]
#1484047
08/14/13 11:48 AM
08/14/13 11:48 AM
Posts: 147 Kansas
cascius
Kansas
Everything. bout the only thing that could be the same is the inside of the bed and that's only width and length . We have an 01 Shortbed
^THIS is what he's trying to find out. He's not trying to use a newer bed on his truck. Just trying to see if a newer slip in bedliner will fit in his older truck.
[Re: 1E2C]
#1484051
08/14/13 11:27 PM
08/14/13 11:27 PM
Posts: 15,487 Florida
scratchnfotraction
Yeah, what the hey?? I'll do like you say and drive the 50 miles to see if it'll fit - it's only 3 hours wasted if it doesn't and I drive back empty. I just figured with the variety of knowledge here someone may have compared these things in the past. Excuse me for looking for a shortcut.
is a spray in bed liner out of the ?
we sparyed a 1 ton flat/dump bed with it and it holds up faily well so far. takes a beating thats for sure.
be on the trailer bed also, trees slid right off of it.
I have a long bed rubber floor mat I can measure up for you.
it is for the 82-93 trucks, looks like it would fit my sons 94 truck.
[Re: 1E2C]
#1484054
08/17/13 10:38 PM
08/17/13 10:38 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The grooves in my bed liner hold dirt, rust from scrap, tree bark and so on... It would be much easier to clean it out if it had a spray on bedliner. I just stick with the plastic to help keep it from getting dented when I toss logs and heavy parts in it.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
