Carb Choice Street Engine 440 #1483633
08/12/13 10:54 PM
08/12/13 10:54 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
This is a street engine. Please help me on carb choice.
440 stock stroke
10,5:1 compression
MP 284° ,528" solid flat tappet MP cam
1 7/8" TTI headers
1.6 roller rockers
performer RPM intake
stealth heads unported
keilser 5 speed trans
I was thinking about using an edelbrock 800 AVS carb????
This is a street engine, not a race engine. Reliability, ease of manteinance and consistency is the main thing.
Re: Carb Choice Street Engine 440 [Re: domingo] #1483634
08/12/13 11:23 PM
08/12/13 11:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be a good choice for a street engine
Re: Carb Choice Street Engine 440 [Re: domingo] #1483635
08/13/13 01:20 AM
08/13/13 01:20 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
the Holley 3310(750 vac.) would also be a good carb for a street 440
72 Plymouth Roadrunner 11.08@123.25
Re: Carb Choice Street Engine 440 [Re: domingo] #1483636
08/13/13 03:04 AM
08/13/13 03:04 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Holley Street Avenger 770 or 870.
Great street carb right out of the box.
Re: Carb Choice Street Engine 440 [Re: topbrent] #1483637
08/13/13 03:31 AM
08/13/13 03:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
go with the 'brock
Re: Carb Choice Street Engine 440 [Re: rebel] #1483638
08/13/13 04:03 AM
08/13/13 04:03 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Thanks for the advice. I will go with the brock 800 avs then.
Now on another note, I want to add a complete MSD ignition system.
What distributor and what ignition box would you use with this engine? opinions?
Re: Carb Choice Street Engine 440 [Re: domingo] #1483639
08/13/13 04:22 AM
08/13/13 04:22 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use a Crane in my 'cuda. even when the battery is low it still kicks into life. my mates Charger with MSD dont do that.
Re: Carb Choice Street Engine 440 [Re: Roughbird72] #1483640
08/13/13 09:53 AM
08/13/13 09:53 AM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Or this. Pretty much the default carb for street hot rods.
Re: Carb Choice Street Engine 440 [Re: topbrent] #1483641
08/13/13 10:04 AM
08/13/13 10:04 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
No such animal from any manufacturer.
If it runs perfectly right out of the box, there's something wrong with the engine.
Re: Carb Choice Street Engine 440 [Re: bobby66] #1483642
08/13/13 10:08 AM
08/13/13 10:08 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
AVS 800 is a good choice, may want a little stiffer metering rod spring (orange I think?) to bring the mains in a bit quicker on a 440. i run that carb on my 427 SBF cobra and it has worked flawlessly and has much better drivability and cleaner idle than any Holley I've ever run on a mild (if 511 hp is mild ) high torque street motor.
a 4779 750DP also works really well on a mild 440 with a pink cam and a 31 shooter
WIZE
In Car:
Re: Carb Choice Street Engine 440 [Re: domingo] #1483643
08/13/13 10:11 AM
08/13/13 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try getting a Firecore dist and see if you can get
a 6-al ignition... might try the Firecore coil also
JMO
Re: Carb Choice Street Engine 440 [Re: domingo] #1483644
08/13/13 12:44 PM
08/13/13 12:44 PM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
Street engine? Whatever you pick, take a distributor with vacuum advance.
Re: Carb Choice Street Engine 440 [Re: fbernard] #1483645
08/13/13 11:22 PM
08/13/13 11:22 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I use MSD Pro Billet, 6Al and Blaster(2?) coil. No vacuum advance, lightest springs and whichever bushing gave the most initial advance, worked great, putting same setup in my 383...
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Carb Choice Street Engine 440 [Re: Sledge_57] #1483646
08/14/13 11:42 AM
08/14/13 11:42 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
What about spark plug choice for that engine???? Any suggestions?
Re: Carb Choice Street Engine 440 [Re: domingo] #1483647
08/14/13 12:17 PM
08/14/13 12:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
750DP....800 thunder is ok.
Coming soon!!!!
Re: Carb Choice Street Engine 440 [Re: domingo] #1483648
08/16/13 07:44 AM
08/16/13 07:44 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I run the 800cfm 1412 Eddy on a similar build, runs great. The stock 750 AVS Carter runs perfect on my 69 GTX, the AVS is a nice working carb, go for it.
Re: Carb Choice Street Engine 440 [Re: 63stabamatic] #1483649
08/16/13 08:43 AM
08/16/13 08:43 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'm going to be the odd man out and say THERMOQUAD!
Really is a great carb once you learn the tricks, I'm half temped to take the pair of AFB's off my tunnel ram and swap them for TQ's.
The 800 CFM Edelbrock Thunder AVS is a fine carb and strip kits are easy to purchase.
Re: Carb Choice Street Engine 440 [Re: gdonovan] #1483650
08/16/13 09:46 AM
08/16/13 09:46 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IF you could find a good 1..
Go for the gusto, put 3 Holley 2300s on it..
I am truckless..
Re: Carb Choice Street Engine 440 [Re: 340SHORTY] #1483651
08/16/13 10:16 AM
08/16/13 10:16 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Plenty of TQ's around, lack of strip kits are the issue for the average consumer. I just drill out or modify my own stuff.
Re: Carb Choice Street Engine 440 [Re: domingo] #1483652
08/16/13 10:24 AM
08/16/13 10:24 AM
Right here
HP2 Offline
HP2  Offline
Right here
Do NOT listen to people saying that you don't need a vacuum distributor on a street car. To keep your engine cold and to get good mileage you DO NEED VACUUM! Period.
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
